Piston Slap?
01-24-2006, 09:17 AM
Piston Slap?
Hi Guys,
I'm recently noticing a nasty knocking sound coming from my engine when it's cold. It's a low frequency tap that is pretty loud these days (subzero temps around here). I can only hear it when the engine is under load. I'm afraid this old engine of mine is on it's way to an early retirement. I suspect it may be a slapping piston, which would explain the sound going away when it's warmed up, question is, will it survive this condition for a while, or should I start putting some money into rebuilding my old engine? FABRICA MI DIEM, PVNC! |
01-24-2006, 10:36 AM
Piston Slap?
If its piston slap, you should be ok..just make sure that you don't load the engine to much when cold..
Then again..the fact that it only does this under load makes me think it might be bearing. A wheel to steer the front of the car A pedal to steer the rear |
01-24-2006, 11:35 AM
Piston Slap?
I would expect a bearing to give a higher pitched noise, but you never know. I'll let you have a listen this weekend. I'm starting to look around for rebuild parts in the meantime...you never know how soon you'll need 'em.
Piston ID | kazi | 5 | 5,828 |
08-11-2019 03:34 PM Last Post: totta Crolla |
86mm piston wizards... | fantapants | 6 | 6,502 |
05-30-2017 02:36 PM Last Post: jdm86gtz |
Piston Identification | Alex170984 | 3 | 5,617 |
05-17-2016 12:47 PM Last Post: Alex170984 |
Piston availability | totta Crolla | 3 | 5,731 |
09-03-2015 09:32 PM Last Post: oldeskewltoy |
which piston is this? | ditn | 10 | 12,567 |
07-04-2014 03:18 PM Last Post: Bean |
