Popup lights problem :( Video inside
02-10-2010, 01:58 AM
Hello I recently imported an a AE86 from Japan,the car was a Levin but it was converted into a Trueno.Now I have a problem,the popup lights turn crazy when I turn them on, the only way to stop that is getting off the wire of the battery.When I connect the wire again the popups stills doing the same. Here's a little demo:
http://www.youtube.com/watch?v=FSsmj0h5vTc What is the problem? arf |
02-10-2010, 08:19 AM
check if you have proper Ground wires ! Then the retractor relay (the one in front of the battery.
AE86 FANATIC!!! |
02-12-2010, 09:51 AM
i purchased a new relay retractor if is the relay the problem.
Thank you |
07-19-2010, 03:31 AM
HEY BY ANY CHANCE DO YOU KNOW WHERE TO BUY ANOTHER RELAY LIKE THAT ONE MY LIGHTS ARE DOING THE SAME SHIT I HAD TO UNPLUG THE CONNECTOR TO THE MOTOR AND LEAVE THEM UP SO I CAN DRIVE AT NIGHT PLEASE HELP BECAUSE THE ONLY ONES I HAVE FOUND COST $40 BUCKS AND THERE USED LET ME KNOW ASAP OK THANKS MIKE
07-19-2010, 09:57 AM
AW11 and other toyotas all use the same retractor relay.
AW11 deffo has same part number. http://www.skynet.ie/~eireae86 |
Inside of front wheel touches frame rails during drifting | bozu | 3 | 1,698 |
06-09-2022 04:51 PM Last Post: Project D |
Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 7,779 |
4agZe problem solved - 99% IC problem | Okami | 41 | 35,626 |
dash lights and park lights problems **Sigh** | adamsaiyad | 5 | 6,337 |
05-07-2010 01:21 PM Last Post: adamsaiyad |
Back-Up (reverse) lights problem | oldskull | 5 | 7,559 |
12-27-2009 10:20 PM Last Post: oldskull |
