Possible Fuel Leak?
12-02-2005, 10:08 AM
What type of management does your car have? MAP or AFM? The AFM versions have an 02 sensor that might cause problems, so if you have one it's a possibility. AFM's can also go bad, but that's pretty rare.
If your engine lacks power then you most likely have some problems under the bonnet. Real fuel leaks tend to have a prominent smell..
Check under the car for wet spots/petrol smell, if you find none then do a readout of the diagnosis system. You never know, an error code might point you in the right direction (although it often spits out the TPS error code when something else is wrong).
Is your watertemp sensor connected and working properly?
Messages In This Thread
Possible Fuel Leak? - Jezza_hr - 12-01-2005, 09:06 PM
[] - banpei - 12-01-2005, 11:33 PM
[] - Yonzie - 12-01-2005, 11:58 PM
[] - Matt Skinner - 12-02-2005, 12:10 AM
[] - Ivan141 - 12-02-2005 10:08 AM
  weird gearbox part2(possible trd set a) ditn 6 7,162 01-31-2016 08:01 PM
Last Post: totta Crolla
  20v block with 16v head and internals possible? ditn 3 7,129 08-12-2014 09:19 PM
Last Post: ditn
  Oil leak (maybe a cylinder head gasket?) max_ae86 15 17,350 11-30-2013 03:59 AM
Last Post: jondee86
  T50 gearbox leak totta Crolla 3 6,055 05-28-2011 06:46 PM
  clutch slave cylinder leak Shane 5 6,342 06-12-2010 12:08 PM
Last Post: Mux213
