Proportioning valve
01-08-2009, 11:28 PM
Proportioning valve
Can anyone tell me where to find the brake proportioning valve and tell me what it looks like, I think mine might be missing Huh
Thanks TC
01-09-2009, 12:44 AM
Proportioning valve
It's a metal thingy on the inner fender (wheel well), close to the brake master cilinder. You should be able to follow the brakelines from the master cilinder to the valve.
01-09-2009, 01:10 AM
Proportioning valve
you can see it in the middle of the pic, where the 2 brakelines from the master run into!
[Image: AEU86 AE86 - Proportioning valve]
01-09-2009, 01:12 AM
Proportioning valve
Thanks Ivan, I have had a look and the rear brake pipe goes straight from the master cylinder to the rear brakes and the front brake pipe goes from the master cylinder into a 'T' piece and then on to the front brakes. I guess the valve should be in the rear brake line ?
01-09-2009, 01:18 AM
Proportioning valve
Ok definately not there then Huh I have seen that thing in a box of spares I got with the car though Smile Good thing I fitted a bias valve in line to the rear brakes. I could still use some more rear bias though (rally car) any ideas other than an adjustable pedal box ?
01-09-2009, 01:19 AM
Proportioning valve
i don't need this setup, so you can have the valve from me if you want?
don't know if there are any moving parts in there, because it's in my shed for at least 4 years allready Tongue
02-07-2009, 08:04 AM
Proportioning valve
What? No proportioning valve? I guess you'd still have stoppers. Maybe? I dunno. Soak that rusty thing in WD40 for a week and then spray air through it; good-as-gnu!
Jason Clark
JC
Atlanta, GA
1984 AE86 SR5 Coupe
1987 MA70 (60-1,.70A/R; AEM EMS)
1994 Honda Accord EX
  4AGE Valve Buckets Scored Steller Engineering 2 855 10-06-2023 05:34 PM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,315 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  HKS valve springs totta Crolla 3 2,116 05-25-2022 10:24 PM
  Valve clearance leon205gti 7 8,537 11-25-2016 03:24 AM
  16v oversize valve seats harkes 9 12,352 09-20-2016 05:04 PM
