Propshaft options
10-07-2010, 07:11 PM
Propshaft options
I've been poking around under my car lately, as I'm getting a few drivetrain vibrations since I installed my TRD engine mounts and I wanted to see what I could do to calm it down.
When looking at my propshaft, it looks like the centre bearing (or the rubber bushing around it) is on the way out or knackered, since there is a fair amount of free play in it. It seems logical this is one of the causes for vibrations, since it happens from 2500rpm up to about 4000rpm.
I'm wondering what the best course of action might be? I've heard that the centre bearing is either not that easy to obtain or replace and it would be worth replacing the whole prop itself. Looking around though, the only example I can see to buy that has a decent write up is from Max at Illegal Garage. Would there be any other options I should look at? And how easy is it to get one fabricated?
10-07-2010, 08:27 PM
Propshaft options
Fabrication is not all that expensive... Just ask at your local propshaft specialist (they exist).
10-13-2010, 08:16 PM
Propshaft options
These people are very good, made me a single piece Ford to Toyota propshaft. No fuss or bother. Propshaft came complete with printout of specs. etc.
http://www.propshaft-services.co.uk/
10-14-2010, 02:29 AM
Propshaft options
Center bearing is expensive, but you can use from Hiluxes from that year. Only difference is the fitment, but thats easy.
Look up my posts on that subject, you will end up with bearing costing 40something bucks.
Then see what's best option for you.
10-14-2010, 11:51 AM
Propshaft options
no offense, but the vibrations come from the engine mounts. Have the same issue in my car (using cusco ones) They are much stiffer than OEM mounts and there for give all the engine vibrations to the front of the chassis. (my hood used to "shake it like you mean it")
Only good solution imo is take oem mounts.
10-15-2010, 12:16 PM
Propshaft options
I found picture of AE86 center bearing support:
[Image: AEU86 AE86 - Propshaft options]
Many Toyotas from that time, +- 10 years have same bearings, the difference is how they are connected to chassis.
Examples:
10-15-2010, 05:22 PM
Propshaft options
so i could just take any bearing from that time and take the center piece and put chassis connection from my old bearing? Smile
and off course messure center hole that can fit...
Thumbs Up ITB filter options mister86 1 3,453 12-06-2020 10:44 AM
  AE86 starter options max_ae86 12 30,242 07-28-2019 08:17 PM
Last Post: harkes
  AE86 rear suspension options 2018 Alex 9 10,882 01-24-2018 02:25 PM
  Rear axle options Dino86 13 12,966 01-08-2018 10:19 PM
Last Post: ditn
  Gearbox and Diff options MIGGZFSU 35 28,063 03-26-2017 12:00 AM
Last Post: MIGGZFSU
