Quaife QSR - Installation & manual steering info
12-13-2007, 08:30 AM
Jimmi either you go to the gym or you could ask Martin Bjerre... He used a rack from an old Carina and an electric servo from a MR2 I think. It wasn't easy but it worked Smile
[Image: AEU86 AE86 - Quaife QSR - Installation &...ering info]
12-13-2007, 06:48 PM
Jimmi The Kid Wrote:When you ad the steering quickeners, the steering wheel will be lighter to turn right? But that will also mean, you got to turn the sterring wheel a lot more, to get the same angel, right? Thats not good. Sad
I fitted the QSR because I want a tighter and more direct steering, but now, I just getting tired in my thin arms, Big Grin
I meant you could add the quickener to a POWERSTEERING equipped vehicle to get quicker response, while having easier steering.
But with the loss of road feel & achievable angle.
Andrew
12-13-2007, 09:34 PM
Mayby I should work out Big Grin
This quickener is good idea, but not the best.
I have found some drawing of the Avensis power steering motor and its not impossible. Fitting the car is not a problem - I think, its just metalwork and will just take some time.
Project AE86 now begun.
Cars I have owned:
Toyota Starlet EP91 1,3 16v Turbo, 200hp
Toyota Starlet EP71 1,3 12v Sport
Mercedes 207D camper, 1977.
Toyota Starlet EP70 with a 174hp Silvertop 20v See video here:
http://videos.streetfire.net/search/Star...079edc.htm
Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint).
Volvo 240 2,1 (The only car I have maked money on).
Toyota Corolla EE90 (my first car)
01-17-2008, 08:52 PM
Great thread on so many ae86 forums
But one question : what is the ratio of the rack ? with this gear set fitted
i am guessing that the NON powersteering racks you have there are the same as ones here
AE86 : 16 : 1
also i have looked at the following for replacing it
SW20{MR2} : 16.6 : 1 , 2.7 in SW20{MR2}
MR-S{MR2} : 13.6 : 1 but the rack is front mounted so would require a gearbox to reverse direction , fitted in a AE86 with its shorted arms is gives 2.2 turns from 2.6 in the MR-S
s13/240sx : ???? No doubt No Hachi will know
s14 : 17.49 : 1
Late EVO : 13 : 1 still trying to get hold of a rack for measurements
EVO CT9A RS RHD 11.8 : 1
MR2 is a manual powersteering rack with a external electric powersteering pump as per MR-S as well. There very unreliable over here and cannot supply the pressure to keep up with going from full lock one direction to the other.
01-17-2008, 11:49 PM
3 of my friend uses the suzuki ignis electris ps column with their quaife qsr.
Its working.
I don't have pictures at this time and I don't know how they did it, but I know the whole thing was under 400 EUR. I'll try to get some pics.
  Wanted: 3-rib engine repair manual Ivan141 6 2,851 09-09-2022 07:46 PM
Last Post: oldeskewltoy
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 7,304 07-31-2019 11:28 AM
  Quaife quick rack totta Crolla 19 21,831 03-03-2018 03:32 PM
Last Post: Deuce Cam
  TRD multi-ECU manual Two Sheds 10 20,577 07-12-2017 12:21 AM
Last Post: jondee86
  AE101 4AGZE workshop manual bozu 1 7,321 04-04-2017 10:52 PM
Last Post: hachirokkos
