Quaife Steering rack tuning problem
01-24-2010, 12:15 PM
A rally friend of mine bought a quick steering rack from Quaife some months ago . He did not fix the steering rack on his car and meanwhile crashes the ae86 into a (crossing road) wall .
As he was absolutely desesperate , he sold the car . And I bought the steering rack from him .
It's new and in the box , never open !
I fixed the rack into and old but working housing with new bearings .
I had a try on road and find it impossible to drive . Hard points and no steering return in corners .
All tunes have been made as in workshop manuals .
So I try to find why .
Do you ever had same problems ?
I was thinking about the rack guide (part n°:45523-20040) that might be out of shape and could'nt fit with the new main axle?
Sorry for that long post
Regards
Phil
Filh
Save the RWD cars
01-24-2010, 12:18 PM
does your car have Powersteering knukels and how low it is?
sound like bumpsteering to me?
01-24-2010, 01:09 PM
Did you overtighten the preload nut on the backside that puts pressure on the rack gear into the pinion gear? (IE: were you able to turn the pinion gear throughout the range of motion after assembly, but before installing the rack into the car?)
What is your caster set at? P/S or Manual knuckles? What size tires are you running?
Andrew
01-27-2010, 12:50 AM
Sorry for my late reply , but I also have Computer problems .
I only have manual steering (no P/S) my tyres : Toyo R1R 195/50/15
pressure 2,1kg
I set caster and camber same as it was with stock steering rack .
The preload on pinion was set as in workshop manual (2kg/cm-2in/lb) a very low value. Pinion is turning free and whithout problem when the rack is not in assy .
But it was very hard to set the rack clearance .
I tried to fix clearance as smooth as possible .
But , by moving the rack from left to right , you can" feel the teeth".
I didn't notice that on the stock steering system .
As it's a racing part and a shorter steering demultiplication , it's easy to understand that the steering wheel will be harder to move .
But , when the car was on his wheels, I had a try and , as I said , felt hard point in steering and no steering return .
I think the guide rack could be the reason of my trouble . See the pic added . That part is as old as the complete steering rack and may perhaps be to old for the new well shaped rack.
what do you think ? I must insist , I have no steering problem with the stock parts on car.
regards
Phil
Filh
Save the RWD cars
02-03-2010, 02:11 PM
looks impossible to solve
Filh
Save the RWD cars
02-23-2010, 11:41 PM
going to throw that to garbage..... Angry
Filh
Save the RWD cars
02-24-2010, 12:48 AM
before you throw it in the garbage - I'll gladly pick it up from you...
02-24-2010, 12:52 AM
Might as well let someone else have a try ;-) sorry though have no idea what the problem could be. Just let me know when you throw it away and I'll come and fish it out of your dumpsterSmile
You're more likely to find the fault once you start pulling it apart again Dumb question
02-26-2010, 01:57 AM
too late , it's gone Cool
Filh
Save the RWD cars
02-26-2010, 09:44 AM
hope you are kidding? I'm in Switzerland at the moment but more than glad to pick it up on my way back to Brussels in a couple of days...
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 10,913 07-31-2019 11:28 AM
  Quaife quick rack totta Crolla 19 28,785 03-03-2018 03:32 PM
Last Post: Deuce Cam
  Why Manual Steering Rack ?? Power Steering Removal juantonwan 26 55,252 10-02-2014 06:07 PM
  Ecu ROM tuning Alex170984 4 7,946 10-13-2013 08:03 AM
Last Post: Apsogos
  AE86 non-power steering problem andee17 3 9,544 07-25-2013 06:41 AM
Last Post: jondee86
