Quaife Steering rack tuning problem
01-24-2010, 12:15 PM
A rally friend of mine bought a quick steering rack from Quaife some months ago . He did not fix the steering rack on his car and meanwhile crashes the ae86 into a (crossing road) wall .
As he was absolutely desesperate , he sold the car . And I bought the steering rack from him . It's new and in the box , never open ! I fixed the rack into and old but working housing with new bearings . I had a try on road and find it impossible to drive . Hard points and no steering return in corners . All tunes have been made as in workshop manuals . So I try to find why . Do you ever had same problems ? I was thinking about the rack guide (part n°:45523-20040) that might be out of shape and could'nt fit with the new main axle? Sorry for that long post Regards Phil Filh Save the RWD cars |
01-24-2010, 12:18 PM
does your car have Powersteering knukels and how low it is?
sound like bumpsteering to me? |
01-24-2010, 01:09 PM
Did you overtighten the preload nut on the backside that puts pressure on the rack gear into the pinion gear? (IE: were you able to turn the pinion gear throughout the range of motion after assembly, but before installing the rack into the car?)
What is your caster set at? P/S or Manual knuckles? What size tires are you running? Andrew |
01-27-2010, 12:50 AM
Sorry for my late reply , but I also have Computer problems .
I only have manual steering (no P/S) my tyres : Toyo R1R 195/50/15 pressure 2,1kg I set caster and camber same as it was with stock steering rack . The preload on pinion was set as in workshop manual (2kg/cm-2in/lb) a very low value. Pinion is turning free and whithout problem when the rack is not in assy . But it was very hard to set the rack clearance . I tried to fix clearance as smooth as possible . But , by moving the rack from left to right , you can" feel the teeth". I didn't notice that on the stock steering system . As it's a racing part and a shorter steering demultiplication , it's easy to understand that the steering wheel will be harder to move . But , when the car was on his wheels, I had a try and , as I said , felt hard point in steering and no steering return . I think the guide rack could be the reason of my trouble . See the pic added . That part is as old as the complete steering rack and may perhaps be to old for the new well shaped rack. what do you think ? I must insist , I have no steering problem with the stock parts on car. regards Phil Filh Save the RWD cars |
02-03-2010, 02:11 PM
looks impossible to solve
02-23-2010, 11:41 PM
going to throw that to garbage.....
![]() Filh Save the RWD cars |
02-24-2010, 12:48 AM
before you throw it in the garbage - I'll gladly pick it up from you...
AE86 ex-daily |
02-24-2010, 12:52 AM
Might as well let someone else have a try ;-) sorry though have no idea what the problem could be. Just let me know when you throw it away and I'll come and fish it out of your dumpster
![]() You're more likely to find the fault once you start pulling it apart again ![]() A wheel to steer the front of the car A pedal to steer the rear |
02-26-2010, 01:57 AM
too late , it's gone
02-26-2010, 09:44 AM
hope you are kidding? I'm in Switzerland at the moment but more than glad to pick it up on my way back to Brussels in a couple of days...
AE86 ex-daily |
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 7,028 |
Quaife quick rack | totta Crolla | 19 | 21,294 |
03-03-2018 03:32 PM Last Post: Deuce Cam |
Why Manual Steering Rack ?? Power Steering Removal | juantonwan | 26 | 44,215 |
Ecu ROM tuning | Alex170984 | 4 | 5,873 |
10-13-2013 08:03 AM Last Post: Apsogos |
AE86 non-power steering problem | andee17 | 3 | 7,377 |
07-25-2013 06:41 AM Last Post: jondee86 |
