Quaife Steering rack tuning problem
01-24-2010, 12:15 PM
A rally friend of mine bought a quick steering rack from Quaife some months ago . He did not fix the steering rack on his car and meanwhile crashes the ae86 into a (crossing road) wall .
As he was absolutely desesperate , he sold the car . And I bought the steering rack from him . It's new and in the box , never open ! I fixed the rack into and old but working housing with new bearings . I had a try on road and find it impossible to drive . Hard points and no steering return in corners . All tunes have been made as in workshop manuals . So I try to find why . Do you ever had same problems ? I was thinking about the rack guide (part n°:45523-20040) that might be out of shape and could'nt fit with the new main axle? Sorry for that long post Regards Phil Filh Save the RWD cars |
01-24-2010, 12:18 PM
does your car have Powersteering knukels and how low it is?
sound like bumpsteering to me? |
01-24-2010, 01:09 PM
Did you overtighten the preload nut on the backside that puts pressure on the rack gear into the pinion gear? (IE: were you able to turn the pinion gear throughout the range of motion after assembly, but before installing the rack into the car?)
What is your caster set at? P/S or Manual knuckles? What size tires are you running? Andrew |
01-27-2010, 12:50 AM
Sorry for my late reply , but I also have Computer problems .
I only have manual steering (no P/S) my tyres : Toyo R1R 195/50/15 pressure 2,1kg I set caster and camber same as it was with stock steering rack . The preload on pinion was set as in workshop manual (2kg/cm-2in/lb) a very low value. Pinion is turning free and whithout problem when the rack is not in assy . But it was very hard to set the rack clearance . I tried to fix clearance as smooth as possible . But , by moving the rack from left to right , you can" feel the teeth". I didn't notice that on the stock steering system . As it's a racing part and a shorter steering demultiplication , it's easy to understand that the steering wheel will be harder to move . But , when the car was on his wheels, I had a try and , as I said , felt hard point in steering and no steering return . I think the guide rack could be the reason of my trouble . See the pic added . That part is as old as the complete steering rack and may perhaps be to old for the new well shaped rack. what do you think ? I must insist , I have no steering problem with the stock parts on car. regards Phil Filh Save the RWD cars |
02-03-2010, 02:11 PM
looks impossible to solve
02-23-2010, 11:41 PM
going to throw that to garbage.....
02-24-2010, 12:48 AM
before you throw it in the garbage - I'll gladly pick it up from you...
AE86 ex-daily |
02-24-2010, 12:52 AM
Might as well let someone else have a try ;-) sorry though have no idea what the problem could be. Just let me know when you throw it away and I'll come and fish it out of your dumpster
You're more likely to find the fault once you start pulling it apart again A wheel to steer the front of the car A pedal to steer the rear |
02-26-2010, 01:57 AM
too late , it's gone
02-26-2010, 09:44 AM
hope you are kidding? I'm in Switzerland at the moment but more than glad to pick it up on my way back to Brussels in a couple of days...
AE86 ex-daily |
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 6,667 |
Quaife quick rack | totta Crolla | 19 | 20,651 |
03-03-2018 03:32 PM Last Post: Deuce Cam |
Why Manual Steering Rack ?? Power Steering Removal | juantonwan | 26 | 42,792 |
Ecu ROM tuning | Alex170984 | 4 | 5,689 |
10-13-2013 08:03 AM Last Post: Apsogos |
AE86 non-power steering problem | andee17 | 3 | 7,191 |
07-25-2013 06:41 AM Last Post: jondee86 |
