Question in the transmission
03-24-2006, 06:50 PM
The french AE86 and the corolla GT (always in france) have a standard differencial or LSD? I think a standard differencial but i've look a pics with sticker LSD in the transmission...
thank you julien |
03-25-2006, 04:29 PM
Probably came with LSD from tjhe factory...
03-28-2006, 10:44 AM
Ivan141 Wrote:Probably came with LSD from tjhe factory... ![]() |
03-28-2006, 11:55 AM
You can check by looking for the "LSD oil only" sticker on the axle, and there is a bit of the chassis code that states which kind of diff it came with from the factory (something like T260 or something,...not too sure what it should be exactly). Easiest way of finding out is doing a donut off course.. also much more fun than looking under the car :wink:
03-28-2006, 12:12 PM
Ivan141 Wrote:You can check by looking for the "LSD oil only" sticker on the axle, and there is a bit of the chassis code that states which kind of diff it came with from the factory (something like T260 or something,...not too sure what it should be exactly). Easiest way of finding out is doing a donut off course.. also much more fun than looking under the car :wink: Salut ![]() Il a raison je croix. For the LSD i thick hat all the AE86 in france comme whith an lsd! I've never heared that The hachi's have an other thing than an lsd ![]() SR Team BURN THE RUBER NOT YOUR SOUL! |
03-28-2006, 09:27 PM
code T283
Gearbox mount and transmission mount | gh0st | 9 | 3,916 |
05-08-2022 03:28 PM Last Post: totta Crolla |
Upgrade transmission or what can I do? | Jimmi The Kid | 7 | 16,261 |
06-12-2010 01:03 PM Last Post: totta Crolla |
T50 Transmission Bell Housing | DRFT | 10 | 28,896 |
01-09-2010 02:58 PM Last Post: DRFT |
transmission overhaul set | peter | 18 | 16,127 |
01-08-2010 10:52 AM Last Post: peter |
Not so DIY: Made a T-50 Bellhousing to W58 transmission adap | assassin10000 | 17 | 57,252 |
12-24-2009 12:15 AM Last Post: assassin10000 |
