Question on rear quauter glass????????
08-13-2009, 07:40 PM
the passenger side rear quater glass leaks very badly! i was looking at the glass and i have no idea how to remove the glass ??? lol. wondering if any body could help me out with this?
thanks Matt |
08-13-2009, 08:01 PM
Carefully (!) remove all the plastic window trimming (it clicks off with a bit of prying). Then unscrew the plastic tabs holding the window down.
Finally, carefully cut through any glue used to seal the window (start with a very small screwdriver or something to poke trough it and continue from there. I'd clean all the old crap from the window and chassis, and use some fresh sealant to glue the window back in place. One last tip: Download the factory manual, it has all the details you need (you'll find it on the aeu86 homepage. FABRICA MI DIEM, PVNC! |
08-14-2009, 03:32 PM
Take the window trim off around the window on the inside - get a mate to hold the window in place and slide a blade down between the body and the window and slowly slice through the seal. Clean it all off once done with thinners and use silicone sealant in a tube to restick the window.
http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
08-18-2009, 01:52 PM
thanks for the help!
Matt |
Can Wing Mirror Glass be Replaced? | chrisae86 | 1 | 1,042 |
03-05-2023 09:34 PM Last Post: Ivan141 |
European/UK vs Japanese Levin "Glass Grill" | mad.matt | 3 | 5,269 |
10-20-2017 02:47 PM Last Post: mad.matt |
Rear Seat Belt Question | sleepercivic | 5 | 9,675 |
06-29-2017 09:30 PM Last Post: banpei |
Refurbishing Kouki "Glass" Grill | mad.matt | 5 | 6,197 |
09-24-2014 10:29 AM Last Post: mad.matt |
Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 5,711 |
