REAR END QUESTIONS
05-08-2008, 05:12 AM
REAR END QUESTIONS
i have a 87 ae86. my rear ind is shot. my posi gave out and it whines real bad. fixing it is not a problem. my question is how do i identify what rear end it is. the car was origanly a sr5. but was converted to a gts. i dont know if the rear end was changed or not. what are the best ways to identifing what rear end it is. i am going to rebuild the posi unit and regear it too. ive got 4 11's in it now and it is way to high. no top end. i just need to know what ring gear i need to get.
thanks for all of the help
matt Thumbs up!
05-08-2008, 11:20 AM
REAR END QUESTIONS
if its got discs its not the sr5 axle
[Image: AEU86 AE86 - REAR END QUESTIONS]
05-08-2008, 11:37 AM
REAR END QUESTIONS
If it has discs it is propably a the GT one with the LSD. Originally they came with 4.3 ring and pinion ratio but you can also have a 4.77 which is shorter.
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 2,056 05-26-2024 07:40 PM
Last Post: totta Crolla
  Windscreen stoopid(?) questions.... Mylesmck 7 988 04-30-2024 09:46 PM
Last Post: Mylesmck
  Brake Bias Questions mad.matt 10 11,118 01-03-2019 04:54 AM
  20v mains & big end bearing izanagi 9 10,300 12-26-2016 12:42 PM
Last Post: pack
  wider rear axle,track width,suspension questions ditn 6 8,610 10-18-2016 11:50 AM
Last Post: fantapants
