RX7 Calipers with Rota Grid V ET0 15x8'
05-22-2013, 05:46 PM
I was thinking about this setup on my car.
Is it possible? Compatible? Need feedback Regards |
05-23-2013, 07:25 AM
yes this should work out
http://nuudelbahn.wordpress.com/ http://www.superlapbattle.lu https://www.facebook.com/SLBRaceleague |
05-23-2013, 11:06 AM
You can always get the calipers cut outs, send them to me and I reply to you if they d fit.
danielvanderwoude Wrote:looks like the nmwisima joke saved you in the endhttp://www.jdmbits.com |
01-08-2015, 12:05 PM
Actually they don't fit 100%.
The knuckle on the RX7 caliper hits the wheel. Needs to be shaved a bit or maybe i'll get a spacer. |
01-08-2015, 01:52 PM
good to know - as I got the calipers on the shelf but never gotten around making an adapter...
I guess it differs with different adapters/discs - what adapter/discs are you using? AE86 ex-daily |
01-08-2015, 07:52 PM
I'm using custom adapters based on the ones that are on the web. The measures are the same probably.
The discs are the Mini Cooper S ones... I have some pictures... They fit. The knuckle on the Caliper is the one hitting the Wheels! Damnnnn |
01-08-2015, 08:51 PM
auch! you need new wheels!!!
01-08-2015, 09:37 PM
I'll make a 3mm spacer that will also serve as center ring for the wheels
Cheers! |
01-08-2015, 10:25 PM
Ah I see so it's not a diameter rather an offset issue. This is very common with ET 0 and lower wheels. A disc with more offset and and corresponding adapter would work too obviously.
AE86 ex-daily |
01-09-2015, 06:14 PM
I'm making a custom spacer that also works as a center ring for the wheels.
Brake calipers identification | FanIsHere | 4 | 4,333 |
10-23-2020 11:45 PM Last Post: FanIsHere |
HOWTO: Mazda FC3S 4pot Calipers | Ian.G | 33 | 50,718 |
01-29-2013 08:31 AM Last Post: Jan Pedersen |
sharing knowledge - RX7 brake adapter | aussiefan | 5 | 10,995 |
04-24-2012 10:58 AM Last Post: Roku_trueno |
4 pot rx7 calipers | Petros AE86 | 17 | 18,558 |
02-20-2012 09:39 PM Last Post: Jimmi The Kid |
Golf Mk4-AudiA4 calipers on rear | Dino86 | 3 | 5,419 |
11-02-2011 05:30 PM Last Post: filh |
