RX7 Calipers with Rota Grid V ET0 15x8'
05-22-2013, 05:46 PM
I was thinking about this setup on my car.
Is it possible? Compatible?
Need feedback Smile
Regards
05-23-2013, 07:25 AM
yes this should work out
http://nuudelbahn.wordpress.com/
http://www.superlapbattle.lu
https://www.facebook.com/SLBRaceleague
05-23-2013, 11:06 AM
You can always get the calipers cut outs, send them to me and I reply to you if they d fit. Thumbs up!
[Image: AEU86 AE86 - RX7 Calipers with Rota Grid V ET0 15x8'] http://www.jdmbits.com
01-08-2015, 12:05 PM
Actually they don't fit 100%.
The knuckle on the RX7 caliper hits the wheel.
Needs to be shaved a bit or maybe i'll get a spacer.
Smile
01-08-2015, 01:52 PM
good to know - as I got the calipers on the shelf but never gotten around making an adapter...
I guess it differs with different adapters/discs - what adapter/discs are you using?
01-08-2015, 07:52 PM
I'm using custom adapters based on the ones that are on the web. The measures are the same probably.
The discs are the Mini Cooper S ones...
I have some pictures...
They fit.
The knuckle on the Caliper is the one hitting the Wheels!
Damnnnn
01-08-2015, 08:51 PM
auch! you need new wheels!!! Tongue
01-08-2015, 09:37 PM
I'll make a 3mm spacer that will also serve as center ring for the wheels Smile
Cheers!
01-08-2015, 10:25 PM
Ah I see so it's not a diameter rather an offset issue. This is very common with ET 0 and lower wheels. A disc with more offset and and corresponding adapter would work too obviously.
01-09-2015, 06:14 PM
I'm making a custom spacer that also works as a center ring for the wheels.
Big Grin
  Brake calipers identification FanIsHere 4 4,331 10-23-2020 11:45 PM
Last Post: FanIsHere
  HOWTO: Mazda FC3S 4pot Calipers Ian.G 33 50,711 01-29-2013 08:31 AM
Last Post: Jan Pedersen
  sharing knowledge - RX7 brake adapter aussiefan 5 10,991 04-24-2012 10:58 AM
Last Post: Roku_trueno
  4 pot rx7 calipers Petros AE86 17 18,557 02-20-2012 09:39 PM
Last Post: Jimmi The Kid
  Golf Mk4-AudiA4 calipers on rear Dino86 3 5,417 11-02-2011 05:30 PM
Last Post: filh
