Radiator for the 4AGZE
02-24-2012, 02:47 PM
Guys,
I'm what's the best radiator for a stock 4AGZE?
I have a dual core massive rad from an old toyota but its too wide and covering most of the areas which I want to run my intercooler piping.
So want to change.
Any suggestions?
A Civic 2 row like this would work??
http://www.ebay.com/itm/ALUMINUM-RADIATO...5890bc0e1e
thanks.
Cheated on my いたずらな女の子 and now I can't get enough of her..
02-24-2012, 03:14 PM
core size seems rather small to me - I'd measure up how much space you need for the piping and then fit the biggest possible you can find... there's no such thing as too big of a radiator - especially in hot countries.
02-24-2012, 03:23 PM
This civic radiators are commonly used in staret turbos, running high turbos and with output usually more than 220hp with no real problem.
I'd say that should be enought for a stock 4agze...
Also why not use a 76c thermostat?
Japan 4 Ever
02-25-2012, 10:15 AM
Try one from a Hyundai excel, should be an easy fit and works fine for my engine, i've got a turbo'ed 4agze
AE86 Levin
  Radiator & grill support panel (Levin) FanIsHere 5 1,984 11-14-2022 10:07 PM
  Alu thick core radiator fitment Gtsi-R 5 2,764 01-26-2022 01:28 PM
Last Post: Gtsi-R
  AE86 F20C swap - Radiator issue mad.matt 3 5,860 02-07-2018 05:14 PM
  Radiator oem or upgrade on racecar? Jimmi The Kid 5 5,621 06-23-2017 05:21 PM
Last Post: pack
  cool lower radiator hose thanos 4 5,341 11-29-2016 01:06 PM
Last Post: thanos
