Rear Seat Belt Question
04-17-2008, 07:38 AM
I did a search and could not find anything. Is it true that European model 86's had 3 point rear seat belts? In the US we only have lap belts for the rear. If this is true I'd love to get a set for the back of my coupe, if any one can help Smile
Thanks,
Rich
04-17-2008, 08:36 AM
True, in Europe 3 point seatbelt was an option. I think only 10% of the cars feature seatbelts.
You have to make a hole in the interiour of the rear C pilar. You can see the marking clearly on the casing, but best to remove them first and then double check the marking.
[Image: AEU86 AE86 - Rear Seat Belt Question]
04-17-2008, 04:13 PM
Excellent, thank you for the info.
Now can anyone help me find a black set of rear belts (for a coupe) if that matters?
Rich
04-22-2008, 07:13 AM
That would b e grea to have pics.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
06-29-2017, 12:57 PM
Anyone has ever installed rear seat belts (3 point) from other model (ex. Celica, VW, etc)?
The AE86 ones aren't easy to find...
Keeping the AE86 alive!
06-29-2017, 09:30 PM (This post was last modified: 06-29-2017 09:32 PM by banpei.)
From experience I know that other models/brands might not be suitable for placement on the AE86. The 3 point seatbelts are intertia belts, so they lock up if they aren't within 3 degrees of their designed angle.
For both the hatchback and 2 door the belts are mounted with something like a 50 degree angle. See also in this video:
So as long as you can find belts with roughly the same angle it should work. But keep in mind those belts are there for safety, so make sure you verify if they work correctly. I always say better safe than sorry. Wink
  Bucket seat prices gh0st 5 2,616 01-23-2022 11:44 PM
Last Post: AlexKTM
  Foam-ectomy on OEM Seat mad.matt 2 4,038 02-17-2017 12:22 AM
  got seat belts. but they rolled up MC_JP 8 9,985 05-06-2014 04:04 PM
  Rear ae86 rear discs & pad part numbers? J-86 4 5,951 11-30-2012 06:32 PM
Last Post: J-86
  AE86 seat belts... Okami 11 15,626 09-27-2012 08:55 PM
