Rear arm length
06-03-2024, 02:25 PM
Rear arm length
As title really, l'm looking for the exact measurement centre to centre of the upper (short)
rear top link.
I have just bought some adjustable links and the ones on my car have been lengthened
by a small amount.
Thanks for any help.
06-03-2024, 08:41 PM
Rear arm length
I might be able to measure tomorrow if no one else can by then.
AE86 ex-daily
06-03-2024, 10:13 PM
Rear arm length
(06-03-2024 08:41 PM)Bean Wrote:  I might be able to measure tomorrow if no one else can by then.
That would be great if you could.
Thank you for offering.
06-04-2024, 10:33 AM
Rear arm length
Mine is currently up on the lift, I'll just have to remember to do it when I get home.
06-04-2024, 07:17 PM
Rear arm length
If you mean the upper link that goes along the car, it's approx 245mm on the OEM non-adjustable one. While I'm at it, the lower is 475mm and the one sideways is set to 797mm. I just used a measuring tape, so I'm probably off by +-2mm or so.
06-04-2024, 07:24 PM
Rear arm length
Great thank you.
l'll check mine against that.
06-05-2024, 12:09 AM
Rear arm length
Upper: 244.7mm
Lower: 474.8mm
Source:
G-ワークス 旧車改造 #05: トヨタ レビン/トレノ AE86
Page 9
06-05-2024, 08:53 AM
Rear arm length
Thank you all for the input.
l can now get the pinion angle correct!
  Lower arm hits toe arm on lock... fullybuiltmiata 12 13,416 01-14-2016 11:52 PM
Last Post: Deuce Cam
  4AGE 20v Ignition Lead Length mad.matt 3 6,599 10-01-2014 03:43 PM
  Door length Ivan141 3 4,910 03-18-2014 02:11 PM
  ae86 crush sleeve length choyr 15 20,580 02-26-2014 05:03 PM
Last Post: choyr
  Length of factory cat Rick 4 7,650 08-07-2013 06:03 AM
Last Post: jondee86
