Rear arm length
06-03-2024, 02:25 PM
Rear arm length
As title really, l'm looking for the exact measurement centre to centre of the upper (short)
rear top link. I have just bought some adjustable links and the ones on my car have been lengthened by a small amount. Thanks for any help. An analogue brain in a digital World |
06-03-2024, 08:41 PM
Rear arm length
I might be able to measure tomorrow if no one else can by then.
AE86 ex-daily |
06-03-2024, 10:13 PM
Rear arm length
(06-03-2024 08:41 PM)Bean Wrote: I might be able to measure tomorrow if no one else can by then.That would be great if you could. Thank you for offering. An analogue brain in a digital World |
06-04-2024, 10:33 AM
Rear arm length | |||
06-04-2024, 07:17 PM
Rear arm length
If you mean the upper link that goes along the car, it's approx 245mm on the OEM non-adjustable one. While I'm at it, the lower is 475mm and the one sideways is set to 797mm. I just used a measuring tape, so I'm probably off by +-2mm or so.
06-04-2024, 07:24 PM
Rear arm length
Great thank you.
l'll check mine against that. An analogue brain in a digital World |
06-05-2024, 12:09 AM
Rear arm length
Upper: 244.7mm
Lower: 474.8mm Source: G-ワークス 旧車改造 #05: トヨタ レビン/トレノ AE86 Page 9 |
06-05-2024, 08:53 AM
Rear arm length
Thank you all for the input.
l can now get the pinion angle correct! An analogue brain in a digital World |
Lower arm hits toe arm on lock... | fullybuiltmiata | 12 | 12,997 |
01-14-2016 11:52 PM Last Post: Deuce Cam |
4AGE 20v Ignition Lead Length | mad.matt | 3 | 6,438 |
Door length | Ivan141 | 3 | 4,760 |
03-18-2014 02:11 PM Last Post: Ivan141 |
ae86 crush sleeve length | choyr | 15 | 20,100 |
02-26-2014 05:03 PM Last Post: choyr |
Length of factory cat | Rick | 4 | 7,439 |
08-07-2013 06:03 AM Last Post: jondee86 |
