Rear axle/diff has gone...
09-11-2012, 05:39 PM
Ivan141 Wrote:Unless its the first time in yonks that you take them out, then it can be a bitch of a job. Make sure you have a slide hammer or something improvised that resembles one when you take on this job. If they have been out recently you can often take them out with a few gentle taps of a rubber mallet (or just by hand), but if they are rotted in there it will be much much harder (the bearings are 3+ cm's wide, that's a lot of surface).
My guess is that they have been out before since the diff (no LSD) has been welded. Wink
[Walaki]D`Lair Wrote:Chances are pretty slim for that m8...its usually the r&p that gives up...
R&P? Undecided
AE86 SWEDEN
https://www.facebook.com/ae86sweden
09-11-2012, 06:09 PM
R&P = ring & pinion = Final Drive Gear:
[Image: AEU86 AE86 - Rear axle/diff has gone...]
09-16-2012, 03:35 PM
It was easy to remove the axles. 4 screws.
One little pull and they slided out. Big Grin
With the pinion in place in the axle-house there seem to be NO movement in sideways of the bearings, so I really cant determine wether there is something wrong with the bearings. They seem to be tight and sliding well.
However the ring is slightly damaged.
BUT the pinion is grinded down to thin sharp razor-blades. Sad
So, now is the question, what do I do now?
1. Buy new bearings (doesnt cost much) even though they seem fine?
2. Buy new pinion?
3. Buy new final gear kit (expensive!!!)?
I dont know what caused this, and dont really want to buy parts if something else is causing this. But there are really no other parts back there can be the problem?
Regards
Håkan
AE86 SWEDEN
09-16-2012, 03:50 PM
that pinion not work. SO you need find ne gear kit. Alwasy their are pair and need bee to geather..
your pinion/ring are not correct position. they have so bad wear and not usable anymore. New used set or New kit and put to geather whit correct speks...
You can see lot of wear on the ring outside.. the contact should bee in middle and i think your was wrong place
09-16-2012, 04:22 PM
Both are dead. you need a new gear kit for sure.
Like said corolla4agze, the contact point between the pinion and the ring should be in the middle, but it seems obvious that on your's it was completly on the outside of the ring Confused
09-17-2012, 02:11 AM
Yeap, they´re fooooked.
Buy bearings and a good 2nd hand gearset or a new one and you probably want to go solid spacer, once you, or whoever is doing it, pulled everything apart... Wink
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
09-17-2012, 08:43 AM
fax0815 Wrote:Yeap, they´re fooooked.
Bearings: ok, 2 of them
Gearset/gear kit: ok pinion and ring
Solid spacer: This pipe/tube?
Regards
Håkan
AE86 SWEDEN
09-17-2012, 09:28 AM
http://www.weirperformance.com/solidpini...rkits.html
09-17-2012, 09:45 AM
Thanks, yes I have now sent an email to Weir to see how much it would cost, compared to Toyota original or used. Smile
Regards
Håkan
AE86 SWEDEN
09-27-2012, 06:21 PM
Toyota wanted about 700 Euro, Weir wants about 350 Euro.
But a guy in Germany who builds gearboxes for racing cars could build new ones for 100 Euro.
So I will go for the cheapest in this case, if its built for racing, it will be good enough for me. Smile
Regards
Håkan
AE86 SWEDEN
  AE86 rear axle weight megabob 11 18,353 03-29-2024 11:18 AM
Last Post: FanIsHere
  Axle width totta Crolla 1 964 10-24-2023 12:20 PM
  Exhaust has white smoke coming out and I dont know why... mister86 3 4,396 01-19-2020 12:06 AM
Last Post: Power_uP
  Rear axle options Dino86 13 12,551 01-08-2018 10:19 PM
Last Post: ditn
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 3,727 12-21-2016 09:37 PM
Last Post: bozu
