Rebuilding T50 Gearbox "synchro job"
05-28-2006, 03:01 PM
Hi
I cannot seem to find any info on this subject???
Any way, i have the know problem of not beeing able to downshift to 2nd without pressing on 1st. Otherwise the gearbox runs fine. I believe i face a "synchro job" but cannot find any info on this? Has anyone done this before - I could use some advise Smile
- Niels
05-28-2006, 03:26 PM
It's easy if you have a press nearby. You should spend around 60€ if everything else is fine.
You will need (almost for sure) 1st and 2nd synchros (around 15€ each) and the gasket kit (20€).
If everything is not so fine, it is also possible that one sleeve (65€) or one bearing (around 90€) needs replacement.
The assembly is not very hard although it requires to read the manual carefully.
Hope this helps
05-28-2006, 05:12 PM
Have you overhauld yours yourself? This manual - have you got a link to it?
05-28-2006, 08:13 PM
Toyota Service Manual
[Image: AEU86 AE86 - Rebuilding T50 Gearbox &..."]
05-28-2006, 09:48 PM
Here is a link:
http://forums.club4ag.com/topic.asp?ARCH..._ID=119687
good luck Smile
  T50 gearbox totta Crolla 3 2,756 02-25-2022 02:35 PM
Last Post: Project D
  T50 TRD gearset DidiDex 7 9,555 09-12-2019 07:36 PM
Last Post: DidiDex
  4A-GE bellhousing on a 20 spline T50 The Doctor 2 7,228 09-30-2016 03:38 PM
Last Post: The Doctor
  T50 gearbox - TRD 2nd and 3rd gear hachirokkos 3 6,905 11-27-2015 10:06 AM
  T50 Gearbox, Fragile ! hachirokkos 10 12,789 11-12-2015 12:06 PM
Last Post: S.K.
