Rebuilding T50 Gearbox "synchro job"
05-28-2006, 03:01 PM
Hi
I cannot seem to find any info on this subject??? Any way, i have the know problem of not beeing able to downshift to 2nd without pressing on 1st. Otherwise the gearbox runs fine. I believe i face a "synchro job" but cannot find any info on this? Has anyone done this before - I could use some advise ![]() - Niels |
05-28-2006, 03:26 PM
It's easy if you have a press nearby. You should spend around 60€ if everything else is fine.
You will need (almost for sure) 1st and 2nd synchros (around 15€ each) and the gasket kit (20€). If everything is not so fine, it is also possible that one sleeve (65€) or one bearing (around 90€) needs replacement. The assembly is not very hard although it requires to read the manual carefully. Hope this helps |
05-28-2006, 05:12 PM
Have you overhauld yours yourself? This manual - have you got a link to it?
05-28-2006, 08:13 PM
Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
05-28-2006, 09:48 PM
T50 gearbox | totta Crolla | 3 | 2,637 |
02-25-2022 02:35 PM Last Post: Project D |
T50 TRD gearset | DidiDex | 7 | 9,246 |
09-12-2019 07:36 PM Last Post: DidiDex |
4A-GE bellhousing on a 20 spline T50 | The Doctor | 2 | 7,115 |
09-30-2016 03:38 PM Last Post: The Doctor |
T50 gearbox - TRD 2nd and 3rd gear | hachirokkos | 3 | 6,771 |
11-27-2015 10:06 AM Last Post: Project D |
T50 Gearbox, Fragile ! | hachirokkos | 10 | 12,466 |
11-12-2015 12:06 PM Last Post: S.K. |
