RedTop Engine?
10-06-2006, 04:09 PM
RedTop Engine?
I know it' has been so often discussed , but I'd like some more explanations!!!I 'm searching for a Redtop small ports engine .
I found a crashed Corolla for sale , but I'm not sure . It's a AE92 FWD Corolla , year 1991, and I'v got an engine pic . You can see it's a TVIS model . I guess it's a big port, but I'm not really sure . What model should I look for to discover that rarity ?Celica Gti Or late AE92. That crashed car is located in France . Any help welcome Filh Save the RWD cars |
10-06-2006, 04:42 PM
RedTop Engine?
That is big port engine.
from Phil Bradshaw's home page Quote:Third Generation 4AGE 89.5-91.6I have a small port engine, but it´s a with AFM. here is pic from small port: http://www.japanmoottorituonti.fi/pics/4age16v.jpg |
10-06-2006, 06:43 PM
RedTop Engine?
Smallport is only delivered in late AE92 GTi. No TVIS of course and most are AFM (In Europe anyway) combined with that fugly EGR-valve.
10-06-2006, 06:52 PM
RedTop Engine?
ok , thanks guys , I 'll search for the late AE92 I guess 1992-1993.
I try to have the entire car to fix everythings with engine ; ECU, harness AFM etc... Thanks Filh Filh Save the RWD cars |
10-06-2006, 07:59 PM
RedTop Engine?
Oh and btw you say that crashed car is from 1991 ? If so then it should have smallport because smallport was introduced somewhere 1989/1990 up untill 04-1992. But it's not a smallport whehehe
10-06-2006, 09:37 PM
RedTop Engine?
After further questions , the owner admitted that it was a late 1988 model.........That's why it's a big port.
I do know now what I'll have to check to find a small port . Thanks Filh Filh Save the RWD cars |
10-10-2006, 09:01 AM
RedTop Engine?
This is definetly a bigport.
Check http://www.ebay.co.uk I just bought a MAPped smallport there and I think there were a few other pieces too. You have to be lucky though to find one because they are really rare. I think you can find also the MAP version in UK easier than anywhere else. |
10-11-2006, 12:44 AM
RedTop Engine?
Thanks , I 'm so often on Ebay . I 've just found 2 AE92 from year 1992
but it would be too expensive to ship here in belgium . Thanks again Fil4545 Filh Save the RWD cars |
10-11-2006, 03:45 AM
RedTop Engine?
i am going to ask a noob question here sorry. what i sthe advantage of a small port engine over the big port.
matt |
10-11-2006, 09:03 AM
RedTop Engine?
matto,
Not 100% sure about this one myself but I believe the smallport engine came with the newer 7rib block which is stronger then the older 3rib block and can handle more power and it had some better lubrication due to some oil thingies they added to it. Don't know what to call em. Also the head itself is a small port which flows the air better then the big port which means better power at lower RPM but theoretically less power at higher RPM so they claim its slightly less rev happy and because the internals are heavier (stronger) it has slightly slower throttle response. So basically, stronger engine, more torque and power at lower RPM and over the rest of the power band, but slightly less revvy and slower throttle responce. There is a good writeup on club4ag about the differences between the 4AG engines btw: http://www.club4ag.com/faq%20and%20tech_...04A-GE.htm Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 8,411 |
NA Build Questions | Blue-/ Redtop questions | d3nso | 18 | 17,031 |
02-25-2013 07:01 PM Last Post: oldeskewltoy |
[Bolt Torque] Bluetop head x Redtop block | JonnyAE86 | 4 | 5,684 |
09-18-2008 11:29 PM Last Post: robokill |
Hicomp Redtop Air Intake Temp sensor - Part #? | celica-fiend | 4 | 4,661 |
05-09-2008 07:51 PM Last Post: F0Bman |
Distributor RedTop vs. Bluetop | meshin | 13 | 17,183 |
12-31-2007 10:28 AM Last Post: meshin |
