Redtop inlet manifold modification for ae86
02-22-2006, 01:08 PM
Anyone tried doing this welding job, and have info on what to watch out for?
Please supply me with pics if possible Smile
My evil Red/Black Panda
My current JDM AE86 project
02-22-2006, 03:38 PM
Looks like a basic cut & weld job to me. Just make sure that the throttle body flange is welded back in place at the correct angle. You'll also need to make some new holes for that throttle cable bracket.
02-22-2006, 04:57 PM
is that my block???
[Image: AEU86 AE86 - Redtop inlet manifold modif...n for ae86]
02-27-2006, 12:10 PM
1. Machine cutting using special bi-metal knife.
2. Argon welding.
AE86 GTS '84 Red Top
03-08-2006, 11:49 AM
you could use a manifold adaptor
but then you have to use 2 gasket sets
Max
[email protected]
03-08-2006, 12:57 PM
And it would probably cost more, and make less power due to the less than ideal shaped intake track. I would prefer a cut-and welded smallport manifold myself. Some people argue that the aesthetics arent very appealing but that all depends on the amount of effort you put into the finish of you welds. (Just look at the differences in the pictures in this thread for example...)
03-08-2006, 10:50 PM
Max_Misawa Wrote:you could use a manifold adaptor
Max
True.....I have come to the conclusion that as a temporary solution, I simply will not spend another $250 on adapters and so forth. I prefer spending between nothing - $50, allthough an adapter would look the best i guess.
03-08-2006, 11:58 PM
Peter.
I´m almost sure that if i had it here , i could have it welded for free!.
I know a lot of helpfull "jyder"
Regards,
Skassa
"""www.turbotoys.dk"""
03-09-2006, 09:42 AM
Hey Skassa....
I´ve been promised by knudsen that he would help me out Smile
All i need to do, is have it send over to him, in conjunction with him taking delivery of his new rear hatch.
03-09-2006, 01:08 PM
Okay, Peter,
Then it´s no problem!
/Skassa
  Smallport inlet manifold totta Crolla 6 3,598 01-17-2022 05:14 PM
  OEM LSD modification malejyetti 40 54,761 06-23-2016 12:34 PM
Last Post: pack
  4age blue top from MR2 same intake manifold? dinkers542 8 10,810 11-02-2014 05:24 PM
Last Post: ditn
  Fuel Tank Modification apardal 1 5,598 08-11-2014 06:59 PM
  4AGTE turbo manifold questions daveskatesallday 3 5,108 08-13-2013 07:38 PM
Last Post: daveskatesallday
