Redtop inlet manifold modification for ae86
02-22-2006, 01:08 PM
Anyone tried doing this welding job, and have info on what to watch out for?
Please supply me with pics if possible ![]() My evil Red/Black Panda http://www.bilgalleri.dk/html/gal_visbil.asp?ID=12832 My current JDM AE86 project http://www.bilgalleri.dk/html/gal_visbil.asp?ID=31609 |
02-22-2006, 03:38 PM
Looks like a basic cut & weld job to me. Just make sure that the throttle body flange is welded back in place at the correct angle. You'll also need to make some new holes for that throttle cable bracket.
02-22-2006, 04:57 PM
is that my block???
02-27-2006, 12:10 PM
1. Machine cutting using special bi-metal knife.
2. Argon welding. AE86 GTS '84 Red Top |
03-08-2006, 11:49 AM
you could use a manifold adaptor
but then you have to use 2 gasket sets Max [email protected] |
03-08-2006, 12:57 PM
And it would probably cost more, and make less power due to the less than ideal shaped intake track. I would prefer a cut-and welded smallport manifold myself. Some people argue that the aesthetics arent very appealing but that all depends on the amount of effort you put into the finish of you welds. (Just look at the differences in the pictures in this thread for example...)
03-08-2006, 10:50 PM
Max_Misawa Wrote:you could use a manifold adaptorTrue.....I have come to the conclusion that as a temporary solution, I simply will not spend another $250 on adapters and so forth. I prefer spending between nothing - $50, allthough an adapter would look the best i guess. My evil Red/Black Panda http://www.bilgalleri.dk/html/gal_visbil.asp?ID=12832 My current JDM AE86 project http://www.bilgalleri.dk/html/gal_visbil.asp?ID=31609 |
03-08-2006, 11:58 PM
Peter.
I´m almost sure that if i had it here , i could have it welded for free!. I know a lot of helpfull "jyder" Regards, Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
03-09-2006, 09:42 AM
Hey Skassa....
I´ve been promised by knudsen that he would help me out ![]() All i need to do, is have it send over to him, in conjunction with him taking delivery of his new rear hatch. My evil Red/Black Panda http://www.bilgalleri.dk/html/gal_visbil.asp?ID=12832 My current JDM AE86 project http://www.bilgalleri.dk/html/gal_visbil.asp?ID=31609 |
03-09-2006, 01:08 PM
Okay, Peter,
Then it´s no problem! /Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
Smallport inlet manifold | totta Crolla | 6 | 3,553 |
01-17-2022 05:14 PM Last Post: oldeskewltoy |
OEM LSD modification | malejyetti | 40 | 54,504 |
06-23-2016 12:34 PM Last Post: pack |
4age blue top from MR2 same intake manifold? | dinkers542 | 8 | 10,769 |
11-02-2014 05:24 PM Last Post: ditn |
Fuel Tank Modification | apardal | 1 | 5,580 |
08-11-2014 06:59 PM Last Post: Ivan141 |
4AGTE turbo manifold questions | daveskatesallday | 3 | 5,072 |
08-13-2013 07:38 PM Last Post: daveskatesallday |
