Revolver coilovers
03-01-2009, 10:00 PM
Revolver coilovers
I have a set of revolver coil overs on my car, and was wondering where I might be able to get replacement damper inserts. the are 8 way adjustable and I suspect they use a commonly available insert.
Dont want to replace all the whole shocks, just the insert. Any help would be cool. Cheers James ![]() http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
03-02-2009, 01:48 AM
Revolver coilovers
remove the damper of your coilover and see what is written above
I think it's the only way to know what kind of damper you have ![]() |
03-23-2009, 07:59 PM
Revolver coilovers
Its probably the same as the one from TRD
03-26-2009, 01:39 AM
Revolver coilovers
yeah actually it might not be.
we've had a car come in once that had these fitted and the dampener is even shorter than a trd short stroke. it seems like the insert they use is very similar to what cusco ect use (used) in their s13 coil overs as far as stroke and body lenght. there is a spacer in there though, so if you can get that out you should be able to shorten it a touch and use normal trd short stroke or HTS 102 ect. i think those inserts though will be kyb brand, which here in australia, are servicable, so could be another option? having said all that its not unlikely there is more than one version of revolver coilover, so yeah, pull it apart and take some measurements ![]() |
Carina drivers! - Coilovers for a TA60/62 | nyberrg | 2 | 6,427 |
06-05-2017 10:03 AM Last Post: nyberrg |
Fitting driftworks CS2 coilovers | bozu | 2 | 4,802 |
05-30-2017 10:50 AM Last Post: bozu |
D2 Coilovers any good? | heshan | 18 | 26,549 |
04-04-2017 02:40 AM Last Post: hachirokkos |
Has anyone tried BC Racing coilovers? | AlexKTM | 9 | 12,190 |
09-05-2016 12:28 PM Last Post: mad.matt |
Anyone running DIY Coilovers? | Rasteirinho | 8 | 13,844 |
11-19-2013 10:30 PM Last Post: totta Crolla |
