Ring & pinion ratio.
06-25-2014, 05:20 PM (This post was last modified: 06-25-2014 05:22 PM by Bean.)
(06-25-2014 11:53 AM)AJPS Wrote:  what sort of top speed to you hit at spa in an ae86?
top speed (~195km/h GPS) on the straight, way before you get to the end.
06-25-2014, 06:19 PM
(06-24-2014 06:50 PM)AJPS Wrote:
(06-24-2014 01:16 PM)Uzelac Wrote:  With 4.778 anything above 100 km/h will be annoying.
unless you are in a race
Of course, but question stated "for daily use" Smile
06-25-2014, 09:52 PM
Tomorrow I will check the ring by following the FSM steps.
This is the only thing that I've forgot to check when I assembled the new bearings.
06-29-2014, 09:08 PM (This post was last modified: 06-29-2014 09:09 PM by izanagi.)
What should I choose for daily drive and drift ?
Is 4.7 not suitable for daily ?
I'm lost in my choice.
06-29-2014, 10:19 PM
(06-29-2014 09:08 PM)izanagi Wrote:  What should I choose for daily drive and drift ?
As said cruising at high speed (i.e. motorway) will be annoying due to high rpm. Do you drive on the motorway or at higher speed in your daily routine?
06-29-2014, 10:44 PM
Yes but i'm also starting drift.
06-29-2014, 11:41 PM
The ability to drift your car is primarily governed by the amount
of power you have, and the amount of grip. Having a Limited Slip
Differential is a big help Smile The only benefit from using a 4.7 instead
of a 4.3 is that you "close up" the gap between gears, and effectively
make each gear a little lower.
First gear with a 4.3 is already very low. Making it even lower will
more or less make it useless, as you will easily be able to start off
in second gear. And, while I am not a drifter, I would guess that
unless you are doing donuts around cones, you are not going to use
first gear much at all.
So, I say use the 4.3 and get yourself a set of wheels with some
skinny tires, pump them up to 45psi and go drifting Smile Then put your
good wheels and tires on for driving to work.
Cheers... jondee86
07-05-2014, 07:35 PM
Get 4.7's if you drift and live with either going slower on the motorway or dealing with higher rpms/noise. IMO.
Andrew
  ring gear bolts DJexor 3 5,368 12-26-2016 10:56 PM
Last Post: totta Crolla
  DIY: a quick outline on why & how to set pinion angle. assassin10000 9 18,192 12-21-2016 10:28 PM
Last Post: ditn
  Checking ring gear diff izanagi 3 4,953 07-09-2014 07:38 AM
Last Post: jondee86
  axle swap time how capable is a std crownwheel and pinion fax0815 32 45,779 09-26-2013 08:33 PM
Last Post: Lajoosh
  Gear end , drive pinion height filh 5 11,084 06-27-2013 12:29 AM
Last Post: filh
