11-29-2009, 01:56 AM
Post: #261
Congrats!! Thumbs up! Thumbs up!
11-29-2009, 03:02 AM
Post: #262
well done lenn!! congratulations Thumbs up! Thumbs up! Thumbs up! Thumbs up!
it sounds very happy Hurray!
http://bruutt.blogspot.nl/
11-29-2009, 10:56 AM
Post: #263
congrats! Yeah the grounding problem is very common. Wave
11-29-2009, 02:05 PM
Post: #264
Len,
You do realise you are running the fuel lines without the copper gasket rings?
Might be part of the leakage problem...
Whats up with the clutch, I thought we had it sorted?
11-29-2009, 04:18 PM
Post: #265
robokill Wrote:And now it did start. You can all laugh as I see my self to be pretty well known with Hachi's. But I forgot a bolt on the intake for grounding the injectors. So my engine checklight failed. My ecu fialed. and my injectors failed Tongue
Heh .. with same problem (after changing the head gasket) i encountered on one AE86. We spent 2 weeks to find the same problem as you had.. Undecided
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
11-29-2009, 04:35 PM
Post: #266
Ivan141 Wrote:Len,
No, I am running with the copper fuel lines. the bit where the rubber hits the metal part is where its leaking not at the bolt.
Regarding the clutch, need to test if its working so far it wasn't. Didn't release or its the clutch I don't know yet. Wasn't able to shift while the engine was running
11-30-2009, 02:15 AM
Post: #267
hey way to go!!
arent you supposed to heat the copper rings up before installing?
11-30-2009, 09:40 AM
Post: #268
Not as far as I know... it's not mentioned in the manual.
We installed the fuel line without them 2 weeks ago because we couldnt find them. Looks like Lennert installed them by now.
BTW, that fuel line was leaking fuel all over the place on my car as well. Strangely enough after having been in storage for almost a year, must be some kind of dry-rot....
11-30-2009, 02:40 PM
Post: #269
I would not take any risk, Lennert is having a new one made.
BTW, we can pick up the rotisserie.
12-05-2009, 12:47 AM
Post: #270
nice, it runs now.
obx is inexpensive, but the reason there's a huge gap for you, is that in the US we have to run a catalytic converter for emissions. bet that gap was about 12 inches??
te72 wagon
ae86 levin coupe project
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 14,745 10-07-2018 09:45 PM
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 158,987 03-28-2018 12:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 727,566 09-03-2017 09:24 PM
  8a9 blue gt coupe McGlinchey 8 9,701 06-22-2016 02:19 PM
Last Post: McGlinchey
  Matt's "Drives as fast as it's Towed" 85 Levin Coupe mad.matt 38 39,543 04-07-2016 12:15 PM
User(s) browsing this thread: 33 Guest(s)
