S2000 Cluster in 86 Corolla ?? pro's plz
06-15-2010, 08:28 PM
Wassup folks..
I was told to install a s2k cluster in a Ae86 corolla.... all u need is the S2k cluster and the S2k dash harness ???
Does anyone have any step by step doing it this way....with stock ECU >?
06-15-2010, 10:06 PM
Never heard of someone installing a s2k cluster in an ae86 without doing the whole engine, gearbox swap. makes no sense, for ex. the speedo is cable driven in ae86 compared to digitial pulsation in s2k.
But if you really want a digital cluster you should go for the jdm gt-apex digi cluster and for that mod there should be info around the net.
280z '75
audi S4 B5 '99
KE25 '71
06-16-2010, 06:26 AM
Sorry,..... i doo have a s2k motor + harness ect
just wann know what else i need to doo on the cluster end ???
06-16-2010, 09:25 AM
There is cable drive -> digital impulse converter and that would make work your km/h and rpm gauges.
Lights are no problem, so only thing left is to think about is fuel and water temperature scales.
06-16-2010, 06:02 PM
If you have everything (dash, engine, harness) you have no reason to have any problem.
Mikzu IV Wrote:Never heard of someone installing a s2k cluster in an ae86 without doing the whole engine, gearbox swap.
That exactly what I am doing Tongue (S2000 cluster in 86 with 4AG)
06-16-2010, 06:37 PM
the swap was hard to make ?
same diff?
AE86 owner
07-03-2010, 01:58 PM
it's not as easy as it sounds as even the fuel gauge used pulse width to set the measured value, or was it the temperature?
07-04-2010, 01:37 PM
Problems you will face:
1. RPM signal needs 12V square wave
2. Electronic speedo is 40 pulses/per rev
3. ECT is a PWMish signal (comes from S2000 ecu)
4. Fuel Gauge slightly off
A s2000 loom won't fix any of those problems. Basically you will need to knowledge in electronics, programming & microcontrollers.
It took me about 6 months (few hours here and there) to get a prototype working in the car. Now im just waiting to finish my engine conversion before I can finalise the design.
[Image: AEU86 AE86 - S2000 Cluster in 86 Corolla ?? pro's plz]
So yes it is possible if you are keen enough. I might make a few more batches of these for enthusists.
07-04-2010, 01:46 PM
way to go Thanh, I love seeing when people go well out of their way to make something happen.
My website:
S-86.com
07-04-2010, 01:49 PM
I love the mad-scientist laboratory theme you have going on there :wink:
Looks similar to my own desk apart from the cooking equipment.
  EUDM gauge cluster banpei 22 4,598 08-15-2023 10:48 PM
  EUDM cluster revelations banpei 1 1,275 06-23-2023 09:11 AM
Last Post: r.ave
  Custom Dash Cluster kazi 14 20,279 10-24-2017 09:05 PM
Last Post: kazi
  EDM GT-S Cluster, PWR light VSV? Rascal21 1 3,998 06-25-2017 08:00 PM
Last Post: Rascal21
  HELP! need AE85 lisse/lime cluster diagram AE86_DRIFTER_ 0 3,548 06-27-2016 11:38 PM
Last Post: AE86_DRIFTER_
User(s) browsing this thread: 12 Guest(s)
