S2000 Cluster in 86 Corolla ?? pro's plz
01-25-2014, 03:25 PM
Post: #41
How much? And is it for F20 or F22?
[Image: AEU86 AE86 - S2000 Cluster in 86 Corolla ?? pro's plz]
01-25-2014, 10:11 PM
Post: #42
Hi its for an AP1, no scratches, comes with the plugs as well!
http://www.trademe.co.nz/Browse/Listing....=688090737
Pic of it here.
10-03-2016, 03:19 AM
Post: #43
Ok it took 6 years to confirm it works Tongue (sorry, i've been bit busy). I've road tested now and it works great <100km/hr its within +/- 1km compared to GPS. At 100km its 5km over - think this has to do with safety margin Honda built-in.
I can make more for s2000 cluster lovers, bare in mind, it take bit longer to make as I need to gather parts together and make them in batches. Leave you interest here.
Product details:
* RPM works with 4age 20v running COPS/stock ignitor-coil (unsure if it can handle 16v should work using IGT signal - definitely runs off IGF)
* Speedo calibrated work 4.3 diff ratio on 185/60r14 & 4ac T50 gearbox
* Correction Factor lets you adjust on fly different gearbox/diff/tyre combos
* Large Speedo correction factor of +/- 5km/hr (up to 30 total)
* Small Speedo correction factor of +/- 1km/hr (up to 7)
* Tested in km/hr (may need a guinea pig for mph)
* Temp control programmed;
* 3-4 bars during normal driving (85-95degC)
* 5-6 bars during stuck traffic (90degC thermo switched thermofan will bring temp down to 4 bars once it kicks in)
What you need to make this work
* Ap1 S2000 cluster + pigtails (immobilizer unlocked version, e.g. JDM)
* Ap1 S2000 fuel sender or you can fiddle around with AE86 + some resisters to get fuel guage working (I use S2000 mechanically adaptered and works GREAT! with Honda quicks :3 )
* M22 Toyota/OEM speed sensor (4-pulse) - Can be found new on ebay cheaply
* 83181-20040 8318120040 949973-0021 5S4893 723880 SN7113
* Extra wiring
* Spare toyota water sensor (2 wire)
* Car not limited to AE86
Attached picture of my $8 bezel with light accessories on
- $5 plastic tub
- $2 steel brackets
- $1 labor of love
10-18-2016, 11:54 AM (This post was last modified: 10-18-2016 11:55 AM by fantapants.)
Post: #44
Thango!!! Good to see you are still kicking Big Grin
Ever get the sr16 going ?
Sent from my HTC_0P6B using Tapatalk
Any chance you could take some time to chat with me about using your smarts in helping me adapt a altezza dash to my beams ? Big Grin
clutch kick, switch, tree .... oowwww
10-19-2016, 01:46 PM
Post: #45
Yep, on to my second life (shell).
I still have the engine but never got a chance to installing it. Engine conversion checks have gotten a whole lot stricter since and it has turned me off Sad May end up selling it as I am enjoying the 20v Smile It feels about right for me.
11-07-2016, 01:46 PM
Post: #46
Thanhngo this stuff is wildly over my head.
But what a the difficulties one could expect to encounter if I wanted to marry something like this s2k cluster with a beams running adaptronic ecu ?
I'm assuming the speed signal could be modified somehow from the stock electronic setup in the j160 and the fuel sender I can modify with a similar pickup... Don't know about water and oil temp /pressures... And stuff...
11-12-2016, 04:56 AM
Post: #47
Yeah it took me awhile to but its mostly just signal conditioning, like translating toyota language to honda language Smile
rpm can be driven directly from adaptronic.
Speed - you need a speedo corrector/multiple that will multiple J160 signal enough to match. I assume its a typical toyota 4-pulse sensor (which is what I use), signal needs to be multiplied at least 10-20x to get the correct speed and then you need finer adjustments to match you drive train/gear. Speedo is within 1km/hr of my GPS signal Smile
Water temp - extra 2 wire toyota temp sensor is needed but this requires a special
11-14-2016, 11:16 AM
Post: #48
Perhaps for signal conversion a Dakota digital SGI-5 might be useful?
AE86 Levin
  EUDM gauge cluster banpei 22 4,339 08-15-2023 10:48 PM
  EUDM cluster revelations banpei 1 1,250 06-23-2023 09:11 AM
Last Post: r.ave
  Custom Dash Cluster kazi 14 20,036 10-24-2017 09:05 PM
Last Post: kazi
  EDM GT-S Cluster, PWR light VSV? Rascal21 1 3,963 06-25-2017 08:00 PM
Last Post: Rascal21
  HELP! need AE85 lisse/lime cluster diagram AE86_DRIFTER_ 0 3,509 06-27-2016 11:38 PM
Last Post: AE86_DRIFTER_
