SPRINGS FOR AE86
06-03-2007, 01:53 PM
SPRINGS FOR AE86
EDIT: Lets make this the place to have a proper discussion about springs for our beloved cars. All about prings for non-adjustable setups.
So i have put together a little list, for all the options that i'm aware of (springrates, lowering, prices, availability): Tanabe GF210 (F:-25mm _ 2.5kg/mm R:-18mm _ 2.7 kg/mm) (cheapest in USA cca 150$; in EU 200 eur+) APEX (F:-30mm _ +30% R:-30mm _ +30%) (availible in EU cca 150 eur) EIBACH Sportkit (F:-25mm _ +30% R:-33mm _ +30%) (availible in EU, price in USA cca 180-200 $) INTRAX (F:-40mm _ +30% R:-40mm _ +30%) (availible in EU, price in USA cca 180-200$ MEGAN Racing (f:-46mm _ +30% r:-43mm _+30%) (availible in USA 120$) ESPELIR Active Super Down (F:-40mm _ 3.0 kg/mm R:-30mm _ 2.8 kg/mm) (availible in japan 80 eur and on) RS*R Ti2000 (F: -20-25mm _ 2.63 kg/mm R: -10-15mm _ 2.33 kg/mm) (availible in japan cca. 60 eur and on) All prices are informative (from online shops and stuff). There are more options (Cobra, TRD ..), so if you know any other with specifications please add.. Your Experiences Please share your experiences with any springs that you might have had . (but only for non-adjustable setups) Pictures Please paste pictures of your car on various springs (all for non adjustable). Measurements of rideheight are welcome naturally. ![]() If this turns out to be a good discussion, maybe we can make a tech faq about springs for the newcomers. PS: Does anybody know the springrates of the stock/oem units? |
06-03-2007, 03:07 PM
SPRINGS FOR AE86
Koni supsension front and rear:
![]() Can not say how much it is down though. Speed Industries Hurdnerwaeldlistr. 73 8808 Pfaeffikon Switzerland e-mail: [email protected] phone: +4155 420 15 69 page: http://www.speed-industries.ch MSN: [email protected] We have all the parts your Hachi needs |
06-03-2007, 03:10 PM
SPRINGS FOR AE86
Hey Apolan, before we start uploading pictures we should first agree on a universal measure of ride height. Just going with what it says on the box is no good, some springs do not give the indicated drop, others give more, some springs sag after time etc etc. Measuring is Always better then guessing no?
Maybe that something like this should be a sticky too. or in the faq. In the miata world it is customary to measure rideheight from the hubcenter to the arch lip. This is a preferred measuring point, since you can relate rideheight issues directly to suspension issues like bumpstopcontact etc. Nice, but doesn't work when you install flares or "custom" arches ala VW golf. I would suggest measuring front and rear rideheight by measuring the distance from the framerail nearest to that wheel to the ground. What I mean by framerail is the long lip running under the sidesills that also contains the jacking points. Measurements of this location should be more or less universal, as long as a car is measured on a relatively flat and horizontal surface (and the rail is more or less intact :-) ) A wheel to steer the front of the car A pedal to steer the rear |
06-03-2007, 08:56 PM
SPRINGS FOR AE86
NoHachi precisely! I've heard apex's sag over time so i'd like to see the actual pictures of various spring setups.. Measuring would be a fine idea. would be nice to have all of that in one place as well so people can better decide on what type of lowering they would like. hence this post.
There isnt alot of options for lowering your hachi. specially in europe. This would apply to normal-stroke setups. (up to cca 40mm lowering) Options that i know for longstroke: Tanabe GF210 (f:-25mm r:-18mm) APEX (f:-30mm r:-30mm) EIBACH Sportkit (f:-25mm r:-33mm) INTRAX (f:-40mm r:-40mm) ESPELIR (f:-40mm r:-40mm) MEGAN Racing (f:-46mm r:-43mm) All of the above are around 30% stiffer than oem units. (around 2.5 kg/mm) |
06-04-2007, 07:54 AM
SPRINGS FOR AE86
TRD springs also belong to your list
![]() I'll see if i can take a pic of the height on mine - but i only have a crappy camera phone. |
06-04-2007, 10:08 AM
SPRINGS FOR AE86
Fallguz Wrote:TRD springs also belong to your list leave the car at the garage and I'll do the rest, pic and measuring ![]() AE86 ex-daily |
06-05-2007, 12:27 AM
SPRINGS FOR AE86
Intrax lowering springs 1.75" drop advertised
![]() Peter Diaz http://www.shiftgearclothing.com http://www.ectoyotas.com/forum/ http://www.facebook.com/elfatherae86 |
06-05-2007, 08:25 AM
SPRINGS FOR AE86
Front Paradise racing coilovers with 6.25kg springs on lowest setting without springs coming loose. Tokico HTS shocks.
Rear Swift B-Tune 4.5Kg springs with Koni AE86 Yellow shocks [img name=]http://www.aeu86.org/files/lo/lowered_456.jpg[/img] Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
06-05-2007, 09:04 AM
SPRINGS FOR AE86
Bean Bandit Wrote:leave the car at the garage and I'll do the rest, pic and measuring you're too cool for school ![]() I'll put it in the garage before I leave for croatia, so you'll have all week ![]() cheers |
06-05-2007, 11:00 PM
SPRINGS FOR AE86
Left: No name lowering springs
Right: TRD 8/6 kg/mm ![]() I guess I better get some coil overs... Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
HKS valve springs | totta Crolla | 3 | 2,476 |
Springs from other vehicles?? | FanIsHere | 16 | 15,255 |
05-17-2016 09:12 AM Last Post: FanIsHere |
3rd door support gas springs (stay) - worn out | max_ae86 | 5 | 6,452 |
09-01-2013 03:20 PM Last Post: Jezza_hr |
Valve springs length | Vil | 4 | 6,057 |
04-04-2013 07:41 PM Last Post: oldeskewltoy |
Maybe problem with TRD shock absorber and springs | Mattolo | 22 | 21,643 |
10-15-2011 07:40 PM Last Post: zenki |
