SPRINGS FOR AE86
06-06-2007, 09:34 AM
SPRINGS FOR AE86
Double post Tongue
06-06-2007, 09:47 AM
SPRINGS FOR AE86
Since I am in the process of looking for better springs, I just
happen to have a whole bunch of measurements handy Smile
Front eyebrow height = 300 (centre of hub to wheel arch)
Rear eyebrow height = 290
Front body seam to ground = 130 (at jacking point)
Rear body seam to ground = 135
[img name=]http://www.aeu86.org/files/84/84ae86gts_554.jpg[/img]
Wheels are 13 x7 with negative 7 offset from memory. The springs
are Jamex (Asian I believe) which give an acceptable ride height, but
they are too soft for even moderately spirited driving.
Cheers... jondee86
06-20-2007, 11:20 AM
SPRINGS FOR AE86
I have edited the first post, so i dont open a new topic since there's some good info here already. Please take a look.
Cheers! Smile
06-20-2007, 06:02 PM
SPRINGS FOR AE86
[Image: AEU86 AE86 - SPRINGS FOR AE86]
Custom wound springs ride height = Stock(+ or - 10 mm)
rates are 4.5 kg/mm front with 3.0 kg/mm rear (stock USA GTS spring rates are 1.9kg/mm front and 2.2 kg/mm rear)
Dan -
08-29-2007, 03:52 PM
SPRINGS FOR AE86
Can anybody explain what 6,5kg means .
what's the stock spring features.
I need much stiffer spring at front but doesn't really know what specifications (meaning about kg/mm)I should look about.
FILH
Filh
Save the RWD cars
08-29-2007, 04:04 PM
SPRINGS FOR AE86
6.5kg/mm means that the compression of 6.5kg (pressure) per MM goes.
so 5mm damping needs around 32.5kg
08-30-2007, 10:48 PM
SPRINGS FOR AE86
So the highest Xkg/mm equal to very stiff springs ?
thanks for the explanation.
Thumbs up!
filh
Filh
Save the RWD cars
08-31-2007, 06:20 PM
SPRINGS FOR AE86
yes the figure says how much force is needed to squish the springs for 1 mm. naturally the springs that need 8kgs to be squished for 1mm are stiffer than the springs that only need say 4 kgs for that 1 mm.
  HKS valve springs totta Crolla 3 2,101 05-25-2022 10:24 PM
  Springs from other vehicles?? FanIsHere 16 14,314 05-17-2016 09:12 AM
Last Post: FanIsHere
  3rd door support gas springs (stay) - worn out max_ae86 5 6,082 09-01-2013 03:20 PM
Last Post: Jezza_hr
  Valve springs length Vil 4 5,762 04-04-2013 07:41 PM
  Maybe problem with TRD shock absorber and springs Mattolo 22 20,231 10-15-2011 07:40 PM
Last Post: zenki
