Sard fuel pressure regulator
08-12-2007, 01:55 PM
Hi,
When I bought my car it already had a SARD fuel pressure regulator mounted. Fuel pressure is about 45 PSI now, for some strange reason it is 5 psi higher than a few weeks ago, but I did not change anything on the engine Confused Unfortunately I do not have the manual for this regulator, does anybody know how it works if I want to adjust the pressure ? Looks quite simple but just want to be sure.
( cannot downlaod the manuel from somewhere .. )
It looks like this :
[Image: AEU86 AE86 - Sard fuel pressure regulator]
What happens to the mixture If I decraese/increase the pressure ?
Since I use an Omex ECU which is callibrated on the dyno I dont want to take any risk.
http://www.heerlijklimburg.nl
08-14-2007, 11:26 AM
If you have a gauge - just adjust the pressure - there should be an adjustment bolt on it. They usually have the top screw turnable - loosen it to raise, tighten it to lower. Do you have the part# for the adapter that goes on the fuel rail?! I really need that part number... =|
08-14-2007, 12:58 PM
Domi : I do not know which adapter you should use for your car, sorry.
Since I use the 4 age and this FPR in my kitcar.
By the way the upper union ( 90degree ) is not connected to anything on my FPR and you can easily turn it around.
08-15-2007, 10:58 AM
That's the one you should turn, then. And i thought the vacuum hose should go there. Rather - i'm almost certain it should. What adapter fitting are you using for that 4AG in the kitcar?
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 21,458 08-19-2018 12:08 PM
Last Post: AlexKTM
  4AGE Fuel Regulator Alex170984 6 10,372 02-24-2016 05:59 PM
Last Post: totta Crolla
  Oil Pressure Query Alex170984 2 5,304 12-11-2014 01:25 AM
Last Post: Alex170984
  Pressure gathering in fuel tank Apolan 9 15,259 05-18-2014 06:18 AM
Last Post: chenfon
  oil pressure high kawo 17 20,879 09-29-2013 12:06 PM
Last Post: allencr
