Sard fuel pressure regulator
08-12-2007, 01:55 PM
Hi,
When I bought my car it already had a SARD fuel pressure regulator mounted. Fuel pressure is about 45 PSI now, for some strange reason it is 5 psi higher than a few weeks ago, but I did not change anything on the engine Unfortunately I do not have the manual for this regulator, does anybody know how it works if I want to adjust the pressure ? Looks quite simple but just want to be sure. ( cannot downlaod the manuel from somewhere .. ) It looks like this : What happens to the mixture If I decraese/increase the pressure ? Since I use an Omex ECU which is callibrated on the dyno I dont want to take any risk. http://www.heerlijklimburg.nl |
08-14-2007, 11:26 AM
If you have a gauge - just adjust the pressure - there should be an adjustment bolt on it. They usually have the top screw turnable - loosen it to raise, tighten it to lower. Do you have the part# for the adapter that goes on the fuel rail?! I really need that part number... =|
08-14-2007, 12:58 PM
Domi : I do not know which adapter you should use for your car, sorry.
Since I use the 4 age and this FPR in my kitcar. By the way the upper union ( 90degree ) is not connected to anything on my FPR and you can easily turn it around. http://www.heerlijklimburg.nl |
08-15-2007, 10:58 AM
That's the one you should turn, then. And i thought the vacuum hose should go there. Rather - i'm almost certain it should. What adapter fitting are you using for that 4AG in the kitcar?
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 20,488 |
4AGE Fuel Regulator | Alex170984 | 6 | 9,765 |
02-24-2016 05:59 PM Last Post: totta Crolla |
Oil Pressure Query | Alex170984 | 2 | 4,953 |
12-11-2014 01:25 AM Last Post: Alex170984 |
Pressure gathering in fuel tank | Apolan | 9 | 14,483 |
05-18-2014 06:18 AM Last Post: chenfon |
oil pressure high | kawo | 17 | 19,772 |
09-29-2013 12:06 PM Last Post: allencr |
