Seeking tech specs for AE86, can u help?
04-10-2007, 07:04 PM
I work for a game company and I am trying to track down the following stock technical specifications for the 1986 Toyota Corolla GTS AE86 USDM
I've hunted around the net and found lots of info on the AE86 in forums and FAQ's etc but I am missing this stuff wheelbase track width front track width rear length, width and height tire sizes front and rear gear ratios for reverse, final drive, 1 2 3 4 5 top speed, 0-60, 1/4 mile, lat-g curb weight If anyone can help me i'd be very grateful, Cheers, Gethin. |
04-10-2007, 08:17 PM
here's a section from what wikipedia has to offer on the subject
Quote:GT-S specifications http://en.wikipedia.org/wiki/Toyota_AE86 GEAR RATIOS for the manual 5 speed tranny (t50): 1st: 3.587 2nd: 2.022 3rd: 1.384 4th: 1.00 5th: 0.861 Reverse: 3.48 Final Drive is as mentioned 4:30:1 Wheelbase is 2400mm flat. I'll try to find other dimmensions to ina sec. |
04-10-2007, 08:21 PM
Wheelbase
2400 mm / 94.5 in Track front 1355 mm / 53.3 in rear 1345 mm / 53 in Length 4180 mm / 164.6 in Width 1625 mm / 64 in Height 1335 mm / 52.6 in Drag coefficient is 0.350 (if you need that to perhaps..) |
04-10-2007, 08:30 PM
The 0-60 and quarter mile times vary from the amount of luxuries in the car; but comparing to (lighter) EUDM 124hp models and JDM 130 hp models which go 0-60 in anywhere from just under 8 to 9 secs. So i guess that would make USDM just under 9 to 10 maybe? i'd say 9 seconds. Quarter mile i'd guess from 16 to 17 seconds.. somebody please confirm.
Max lateral G-s would again depend on the amount of luxuries, type of rubber fitted and asphalt beeing driven on.. back in the days i'd guess 0.8 ish.. |
04-10-2007, 08:33 PM
Superb!
VERY much appreciated! |
Also check in Homebrew Media section - some models.
04-10-2007, 09:15 PM
Apolan: can you sum that up in one post? Might be worth placing in the techref.
04-10-2007, 11:20 PM
EDIT: Okay i changed the apperance, im satisfied.
![]() Please do correct me if im wrong. There is alot of contradictory material on the internet, i did my best to make sense out of it. Im missing the swaybar thicknesses, thy slipped my mind atm, so if anyone has them... Also teh performance figures are figurative ![]() cheers,saso |
04-11-2007, 08:33 AM
Thanks!
![]() I've splitted it into the technical section: http://www.aeu86.org/index/technical-ae8...topic=4815 Unfortunately you can't change anything now. If you want anything changed just pm me. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
04-11-2007, 09:48 AM
no problem.
Can you name these Enkei wheels? | midnightrider | 1 | 3,483 |
01-11-2009 10:34 PM Last Post: midnightrider |
hi everyone my name is tariq , you can call me tarook86 | Dorikin86 | 4 | 4,726 |
12-31-2007 04:25 AM Last Post: Sgonzalez |
