She's finally back on the road
02-01-2010, 08:47 PM
hey guys I finally get to enjoy my car
350z engine works awesome, plenty of power
all over and doesnt understeer !!
been a year since my last event so I went to the local skidpad
http://www.youtube.com/watch?v=EmX2o-gYYYs
02-01-2010, 10:38 PM
Awesome engine you got in there.. pretty unique too.
02-01-2010, 11:43 PM
awesome job done there Thumbs up!
'87 levin coupé
[Image: AEU86 AE86 - She's finally back on the road]
02-01-2010, 11:58 PM
Great engine sound. I like it, allthough it's little akward in 86.
Vladimir
N/A for life...
02-02-2010, 01:18 AM
thanks guys, im having a problem with the steering on the switchbacks.
i have to really flick the wheel to counter instead of just letting it go.
any way to fix this?? im running s13 power steering rack btw
02-02-2010, 08:48 AM
do you have pics of the steering setup when the car is on the ground? on s13 this usualy only happens when the steering angle is increased and the lockstops removed - leading to the tie rods getting in an akward angle where you need to snapp them out of... (think it's called something like steering going over center in english or something like that)
02-02-2010, 02:10 PM
ill try and snap some pics, i definitely have to fix this problem
02-02-2010, 03:05 PM
Not much use making pics. You will need to have it aligned. Go to a shop that does racing alignments and tell them about your problem. They can check whats happening while your car is on the turningplates.
My guess is that its a simple, but serious, alignment problem. Assuming that the original AE86 suspension is still in one piece and has not been hacked etc.
Other options, loose steering rack, jammed steering rack (should feel extra drag).
02-03-2010, 01:24 AM
Im using complete s13 front subframe, spl inner and outer tie rods
power steering is hooked up and still using the stock 86 tension rods
maxed out to the 3* caster
aligment settings are
-3* front camber
0 toe
3* caster
-2* rear camber
0* toe
02-03-2010, 11:56 AM
hey alx954
is it just binding at full lock?
and is hard to pull off that point? This is common with nissans, and especially with 86 running s13 as the equivelant "lowering" is drastic with the 86 crossmmber. You need to get a solution that stops the stearing becoming a straight line. Alot of guys here in oz are moving the stearing rack forward, myself and a mate with a s13 have both gone for max knuckle extensions.
Worked REALLY well in my case, he binding has disappeared and i have a decent kick in lock also.
pm me if you want some more details Smile
Was "this" close to doing the vq engine transplant befor i decided on my beams lol.... great work!
clutch kick, switch, tree .... oowwww
  time to get her back on the road.. worholm 4 9,939 01-21-2017 09:33 AM
Last Post: worholm
  Its in Finally Alex170984 3 8,098 07-16-2013 04:01 PM
Last Post: Alex170984
  86er's Track rebuild N2.??? Finally an update page 8 86er 191 328,170 03-25-2012 10:05 AM
Last Post: bozu
  OST-015: The long and winding road..... oldeskewltoy 19 34,597 12-21-2011 02:50 AM
  Ricks project AE85 (Back together with dyno results) Rick 132 287,387 07-05-2011 11:54 AM
Last Post: Rick
