Simple Question about Fuel Pump Mount
04-25-2008, 01:38 PM
I have an SR5 and am doing the GTS swap. So far things are going alright, but our fuel pump needs a GTS bracket.
Is the bracket native to the ae86 or can we use an AE92 GTS or a MR2 fuel pump mount? If not, how much will the bracket run me (could not find online). Thanks! |
04-26-2008, 06:01 PM
bump?
04-27-2008, 12:07 PM
You need the AE86 bracket.
04-27-2008, 03:28 PM
Yes you do need it because the tanks are different as well.
East Coast Toyota http://ectoyotas.com/forum/index.ph Club4AG http://www.club4ag.com/ |
04-28-2008, 02:22 AM
The only difference between an SR5 and a GTS tank is that the GTS tank has better baffling around the pickup. You can still happily use an SR5 tank, although you may suffer with a bit of fuel surge.
Brackets from other cars may well fit the bolt pattern, however obviously the length is the critical issue. |
04-28-2008, 04:46 AM
Thanks all for the replies. It is much appreciated. Turns out I will just be getting an entire GTS tank since someone local had it.
Thanks for your insight! |
04-28-2008, 08:43 AM
Make sure you have a look inside with a torch to make sure it isn't rusted
05-01-2008, 01:11 AM
Tanks are different so good luck or buy a new race tank.
05-01-2008, 09:35 AM
No, tanks are identical except for internal baffling differences.
GTS pump bracket bolts into SR5 tank. |
20v BT - which oil pump? | Mylesmck | 4 | 2,591 |
Gearbox mount and transmission mount | gh0st | 9 | 3,264 |
05-08-2022 03:28 PM Last Post: totta Crolla |
Fuel pump issue | DJexor | 11 | 4,861 |
fuel line hose from the pump | Wikizz | 4 | 5,957 |
10-16-2017 07:11 PM Last Post: jdm86gtz |
AE86 top mount | totta Crolla | 0 | 3,331 |
11-10-2016 08:04 PM Last Post: totta Crolla |
