Small Port Swap
11-20-2016, 02:07 AM
Small Port Swap
Hi,
I am going to be embarking upon a bigport to mongrel smallport swap.
I am using small port pistons, but bigport crank and rods, but also the smallport head and inlet manifold but retaining my bigport ECU.
I have read articles and threads about a flat spot occurring at 2k rpm when people swap to smallport from bigport and it's down to the TVIS being deleted.
I have jammed my TVIS open on my current engine because it is restrictive for my high lift cams, so in essence, i have deleted the TVIS but haven't physically removed the butterflies or plate.
I was under the impression due to my cam setup that this apparent flat spot would be there if I was running standard cams, but because I am not, i haven't noticed it...I thought this would be the same when I swap over to the small port head and inlet manifold.
Has anyone been victim of this flat spot?
Cheers
11-21-2016, 01:46 PM
Small Port Swap
I have since seen conflicting threads saying it's a load of rubbish.
  Early tvis red top from e9 gti small or bigport? Ryo 3 7,768 04-20-2018 09:14 AM
  Small Port 10.3 Pistons Alex170984 1 4,507 10-25-2016 09:18 PM
Last Post: oldeskewltoy
  Small question about wheels Vortrex 6 8,779 07-19-2013 01:43 PM
Last Post: DJexor
  4age intake side (port) dimensions Uzelac 15 36,288 03-03-2011 12:43 AM
Last Post: Uzelac
  small port engine totta Crolla 4 6,032 07-03-2010 10:05 PM
Last Post: totta Crolla
