Speed Sensor Location?
01-25-2008, 03:10 PM
I'm having a problem with the speedometer not working in my 86 and one thing that was suggested was that I check the speed sensor.
Anyone know where the speed sensor is located? Everything else works on the dash so it makes sense that the sensor might be faulty. Thanks, Matt |
01-25-2008, 03:46 PM
If you have the analogue cluster the speedometer cable is going from the gearbox to the back of the speedometer. The back of the speedometer picks up the revolutions of the cable and translates them into the speed. So the sensor is inside the cluster itself.
If you have a digital cluster the sensor is inside the gearbox and sent electronically to the cluster. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
| map sensor cheating? | fdsjakl890 | 8 | 4,045 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| Lambda sensor wiring | sam3007 | 10 | 9,452 |
| Placement location fuel filter | bozu | 0 | 4,981 |
12-01-2016 11:06 AM Last Post: bozu |
| AE86 Engine Coolant Temp Sensor | izanagi | 8 | 24,829 |
09-06-2014 05:47 PM Last Post: izanagi |
| Hall sensor | totta Crolla | 7 | 11,065 |
02-28-2014 10:07 AM Last Post: Ivan141 |
![AEU86 AE86 - Speed Sensor Location? [Image: AEU86 AE86 - Speed Sensor Location?]](https://www.aeu86.org/sticker-banner-468.gif)
