Speed sensor
12-27-2008, 03:26 PM
Speed sensor
Can anyone tell me what the effect of running the car without the speedo cable attached to the gearbox would be ?
Diagnostic test brings up a code 9 fault "speed sensor" which is not surprising as the speedo cable does not fit the Ford gearbox I have fitted ! An analogue brain in a digital World |
12-28-2008, 12:24 AM
Speed sensor
There is a reed switch in the speedo that outputs a pulse to the ECU.
AFAIK it is only used to activate a speed cut on some models. If the signal is missing it throws a fault. For what its worth, I ran my car with the speedo cable disconnected a couple of times, and didn't notice any change in performance, and don't remember getting a CEL. Cheers... jondee86 |
12-28-2008, 10:43 PM
Speed sensor
Mux drove his car with a broken speedo cable for some time... Can't remember him getting faultcodes either.
1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
Lambda sensor wiring | sam3007 | 10 | 4,925 |
AE86 Engine Coolant Temp Sensor | izanagi | 8 | 20,865 |
09-06-2014 05:47 PM Last Post: izanagi |
Hall sensor | totta Crolla | 7 | 8,537 |
02-28-2014 10:07 AM Last Post: Ivan141 |
Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE | Homem Bomba | 3 | 11,409 |
10-25-2013 05:13 PM Last Post: Apsogos |
1/8 BSPT adapter for oil pressure sensor | Dino86 | 4 | 7,319 |
06-15-2013 12:34 PM Last Post: S.K. |
User(s) browsing this thread:
