Speedo
09-08-2006, 08:28 PM
Speedo
Hi there recently got a trueno
the back lights on the dash dont work
my speedo is in KM i need to convert to MPH
my speedo works the distance traveled works
but total milage does not go up
any ideas people
09-08-2006, 10:57 PM
Speedo
hmm.... first of all welcome to the forum.
Back light on the dash: mine dont work either.. probably a faulty rheostat on your lightswitch, or a broken wire. Try slapping the area around the lightswitch and see if you can get it to light up, if it does it's one of the above problems. I used to be able to slap some sense into it before my dash lighting quit completely.
Speedo conversion: where are you? USA or UK? Get yourself a replacement gauge cluster and solve that and the remaining problems.
09-08-2006, 11:13 PM
Speedo
cheers ivan
in the UK
yeah slapping it doesnt work
pain in the ass
09-09-2006, 10:34 AM
Speedo
Then first thing to check is the lightswitch itself... In the AE86 manual the electric repair section handles the lightswitch, so you should be able to see if the switch is causing it. Otherwise you can see in the same section some hints where to check for the backlightning on the gaugecluster connector and see if you can follow the cable and check it further down. Smile
[Image: AEU86 AE86 - Speedo]
  Speedo Gear d3nso 6 9,979 04-14-2014 09:56 PM
Last Post: d3nso
  Speedo wire on dash? 4000GT 1 3,526 05-24-2010 10:14 AM
Last Post: 4000GT
  removing and replacing speedo wormgear? Jezza_hr 5 6,238 09-03-2008 05:36 AM
Last Post: F0Bman
  Digi dash speedo JamesH 3 4,989 05-10-2007 06:25 PM
  Japanese speedo conversion eight-six 2 4,362 02-15-2006 10:45 PM
Last Post: mykkk
