Speedo
09-08-2006, 08:28 PM
Speedo
Hi there recently got a trueno
the back lights on the dash dont work my speedo is in KM i need to convert to MPH my speedo works the distance traveled works but total milage does not go up any ideas people |
09-08-2006, 10:57 PM
Speedo
hmm.... first of all welcome to the forum.
Back light on the dash: mine dont work either.. probably a faulty rheostat on your lightswitch, or a broken wire. Try slapping the area around the lightswitch and see if you can get it to light up, if it does it's one of the above problems. I used to be able to slap some sense into it before my dash lighting quit completely. Speedo conversion: where are you? USA or UK? Get yourself a replacement gauge cluster and solve that and the remaining problems. FABRICA MI DIEM, PVNC! |
09-08-2006, 11:13 PM
Speedo
cheers ivan
in the UK yeah slapping it doesnt work pain in the ass |
09-09-2006, 10:34 AM
Speedo
Then first thing to check is the lightswitch itself... In the AE86 manual the electric repair section handles the lightswitch, so you should be able to see if the switch is causing it. Otherwise you can see in the same section some hints where to check for the backlightning on the gaugecluster connector and see if you can follow the cable and check it further down.
Speedo Gear | d3nso | 6 | 9,619 |
04-14-2014 09:56 PM Last Post: d3nso |
Speedo wire on dash? | 4000GT | 1 | 3,379 |
05-24-2010 10:14 AM Last Post: 4000GT |
removing and replacing speedo wormgear? | Jezza_hr | 5 | 5,837 |
09-03-2008 05:36 AM Last Post: F0Bman |
Digi dash speedo | JamesH | 3 | 4,737 |
05-10-2007 06:25 PM Last Post: Ivan141 |
Japanese speedo conversion | eight-six | 2 | 4,137 |
02-15-2006 10:45 PM Last Post: mykkk |
