Springs from other vehicles??
05-14-2016, 11:10 PM (This post was last modified: 05-14-2016 11:11 PM by FanIsHere.)
I have a simple question for you...
I am searching on replacing my APEX springs (on KONIs sport), because they are almost dead. Does anyone know from which models I can use the front and from which the rear springs?
For example Eibach and H&R don't produce springs for the AE86. Do they fit directly from another car? I've heard something about rear Eibachs from a Nissan, but I don't know more.
Part numbers would help also.
[Image: AEU86 AE86 - Springs from other vehicles??]
Follow: The story of my AE86
05-15-2016, 10:59 AM
You 've lot of possibilities from USA, Japan or even Europe makes
Eibach has a kit for the ae86 (pro kit for corolla GTS 85-87).
In Europe, easy to find Interalloy (-4cm), cobra spring, fensport ....
Depends what you want
05-15-2016, 12:57 PM (This post was last modified: 05-15-2016 01:05 PM by FanIsHere.)
(05-15-2016 10:59 AM)demee76 Wrote:  You 've lot of possibilities from USA, Japan or even Europe makes
I want something between -2cm and -4cm as I'm using the car as a daily and I'm going to join some track days every now and then (~once every two months). So I am looking for stiff springs on normal high.
But I heard that I can use Eibach and H&R springs from other vehicles, that they are affordable and easy to find.
Do you have any European links for those you said?
05-16-2016, 09:29 AM (This post was last modified: 05-16-2016 09:30 AM by d3nso.)
Don't know wheres the problem to find one of these:
http://www.europerformance.co.uk/pages/p...ingsprings
http://www.dcperformance.co.uk/list/lowe...rolla.html
http://www.ebay.de/itm/DIRENZA-SPORTFEDE...SwPcVVyLZ4
http://www.ebay.de/itm/KAW-FEDERN-fur-To...SwYmZXIe0R
Daily Beater: Civic EG5
Work in progress Car: AE86
05-16-2016, 10:10 AM
(05-16-2016 09:29 AM)d3nso Wrote:  Don't know wheres the problem to find one of these:
The problem there, at least in my case, is that none of them come with a tuv Gutachten.
I believe the eibach ones did back in the day. You're based in Germany though right? What are you running in yours at the moment?
Sent from my SM-T550 using Tapatalk
05-16-2016, 10:50 AM
You have Megan Springs for sale in USA (that are a nice buy though...)
For me the best option... =)
Still you have to check if they're compatible with your MOT rules....
05-16-2016, 02:06 PM
You 're the best!
Any suggestions on these? Keep in mind that I'm using it daily and join some track days (time attack) every now and then.
I think I prefer the APEX.
05-16-2016, 02:28 PM (This post was last modified: 05-16-2016 03:59 PM by d3nso.)
I would run APEX or Cobra springs.
(05-16-2016 10:10 AM)Nakilad Wrote:  The problem there, at least in my case, is that none of them come with a tuv Gutachten.
At the moment I run BC Racing Coilovers. But my car isn't registerd yet. I have a set of rebuild struts with APEX springs also as backup.
05-16-2016, 05:03 PM
(05-16-2016 02:28 PM)d3nso Wrote:  I would run APEX or Cobra springs.
Had apex springs on myself, but the tuv guy told me to go away and get a Gutachten. Ended up putting some standard ones back in just to get on the road.
05-16-2016, 05:09 PM
When I had the APEX springs on my car back in the day they came with a certificate (TUV). Bought them new from official distributor.
AE86 ex-daily
  HKS valve springs totta Crolla 3 2,226 05-25-2022 10:24 PM
Last Post: oldeskewltoy
  3rd door support gas springs (stay) - worn out max_ae86 5 6,226 09-01-2013 03:20 PM
Last Post: Jezza_hr
  Valve springs length Vil 4 5,852 04-04-2013 07:41 PM
  AE86 Body Panels - From Other Toyotas? yellowsnow4free 5 7,896 01-24-2013 04:19 AM
Last Post: yellowsnow4free
  track questions:max oil/water temp,egt and other ditn 7 8,070 07-06-2012 12:40 PM
Last Post: ditn
User(s) browsing this thread: 22 Guest(s)
