Standard crown wheel / pinion
03-11-2008, 09:34 PM
Does anyone know how many teeth there are on a standard (4.3) crown wheel and pinion ? Thanks
03-11-2008, 10:11 PM
The 4.3 comes from:
43/10 = 4.3
So there are 43 teeth on the crown and 10 on the pinion Cool
03-11-2008, 10:16 PM
yeah man !!! you put a 9 teeth pinion and you have a 4.778 !!! Tongue
  DIY: a quick outline on why & how to set pinion angle. assassin10000 9 18,963 12-21-2016 10:28 PM
Last Post: ditn
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 3,927 12-21-2016 09:37 PM
Last Post: bozu
  Ring & pinion ratio. izanagi 27 28,821 07-05-2014 07:35 PM
Last Post: assassin10000
  axle swap time how capable is a std crownwheel and pinion fax0815 32 48,093 09-26-2013 08:33 PM
Last Post: Lajoosh
  part numbers on standard cams Alex170984 10 11,284 09-19-2013 02:53 PM
Last Post: pack
