Standard crown wheel / pinion
03-11-2008, 09:34 PM
Does anyone know how many teeth there are on a standard (4.3) crown wheel and pinion ? Thanks
03-11-2008, 10:11 PM
The 4.3 comes from:
43/10 = 4.3 So there are 43 teeth on the crown and 10 on the pinion Toyota Corolla KE30 + Toyota Corolla AE86 |
03-11-2008, 10:16 PM
yeah man !!! you put a 9 teeth pinion and you have a 4.778 !!!
AE86 FANATIC!!! |
DIY: a quick outline on why & how to set pinion angle. | assassin10000 | 9 | 17,830 |
Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 3,717 |
Ring & pinion ratio. | izanagi | 27 | 26,352 |
07-05-2014 07:35 PM Last Post: assassin10000 |
axle swap time how capable is a std crownwheel and pinion | fax0815 | 32 | 45,229 |
09-26-2013 08:33 PM Last Post: Lajoosh |
part numbers on standard cams | Alex170984 | 10 | 10,463 |
09-19-2013 02:53 PM Last Post: pack |
