Starter Motor Help
11-24-2013, 10:16 PM
Starter Motor Help
Was hoping to find an answer for this on the web but some articles seem to contradict others.
I have been trying to get my 16v started for a while now and after lots of trial and error i have killed my starter motor. Some people say the best and cheapest option is reconditioning however some people say there are other compatible parts? I have attached some photos of the starter, can anyone tell me how hard it is to get a cheap replacement? where these installed on the AW11's? Thanks. Edit: apparently the image is too large to attach, i have heard three different starters where used on the AE86's f this is true how do I determine which one i have? |
11-25-2013, 01:26 AM
Starter Motor Help
Every 16V startermotor, AE82, AE92, MR2 will fit and work!
I´ve tried 16V redtop bigport and smallport starter on an AE86 and they work. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
11-25-2013, 11:16 AM
Starter Motor Help
phill 92 Wrote:Was hoping to find an answer for this on the web but some articles seem to contradict others. check this , if you need to relocate the starter..... as fax0815 said you can install any of all these starters....i used the 4afe starter cause it is smaller 4age 16v to FR 20VT |
| AE86 starter options | max_ae86 | 12 | 34,617 |
07-28-2019 08:17 PM Last Post: harkes |
| Starter problems | Widar | 49 | 139,301 |
02-09-2015 10:11 AM Last Post: Ivan141 |
| motor oil for 16V | kawo | 18 | 32,777 |
11-25-2013 11:18 AM Last Post: Apsogos |
| Starter motor questions - rebuild | Jezza_hr | 6 | 9,772 |
08-31-2013 03:05 PM Last Post: Apsogos |
| How to fix a floating idle on a Toyota 4A-GE motor | Homem Bomba | 8 | 26,968 |
08-27-2013 12:55 AM Last Post: jondee86 |
