Starter problems
04-17-2005, 10:48 AM
Starter problems
Did you try bridging it? (direct wire from battery to small terminal on starter). As I said before, I had this problem many times over, and if you only hear a clicking relay then you probably have a loose or broken wire somewhere. You can easily check by taking off the oil filter (if you still have the bottom exhaust heat shield, otherwise you can probably see what your doing anyway).
I really cant understand this "it doesnt work so the part must be changed" attitude. I would probably have wasted 4 perfectly good starters if I did this everytime I couldnt start my car. So far I've had starter wires come loose, immobiliser failure, and when I just bought it bearing failure (it did turn over a little bit then). These days I've taken out the immobiliser, have new bearings in the starter and my engine fires up on the second revolution of the starter engine.
04-17-2005, 12:33 PM
Starter problems
You need to spend 200 kr and fix your starter... I'm not sure what the parts are called but I can show you pix later Cool
[Image: AEU86 AE86 - Starter problems]
04-17-2005, 02:57 PM
Starter problems
... when mine didn't start it was the wire i wiggled it around a bit and it would start the wire is really small and thin ....
04-17-2005, 03:10 PM
Starter problems
wht not spray lubricants on it.... keehehehe jk only Hurray!
FBH(fucking big hammer)heheheehehehe..... :mrgreen:
04-17-2005, 03:44 PM
Starter problems
This is what you need:
04-22-2005, 09:48 PM
Starter problems
I had that problem on my AE82... the problem was starter selenoid switch [i think thats whats caled]..
I couldn't find a new one, so I disamble old one and olied it... it works for now [5 months]...
08-31-2005, 08:26 PM
Starter problems
Changed the topic title and made it a sticky.
I suffer from the same problem at the moment. Battery fully charged, all I hear is a click and 1 out of 10 times it makes about a half revolution. I guess it is not a loose connection but something with the starter.
Anyone got a good pic to show me where to apply the BFH? Dumb question
09-01-2005, 07:20 AM
Starter problems
Look into my project, I had a problem with a starter too...
The common problem on the starters is, that the B+ contact gets galvanised during usage (the pic of galvanised contact is shown there).
So the electric contact is poor - the consequence is that only few % of the current flows, so the starter doesn't have enough power to turn the engine or it turn's it just a few times...
The other case is that the pinion doesn't return when the car starts.
A friend of mine dissasembled and changed contact, as his department in the company produces starters Smile
Regards
Andrej
09-01-2005, 09:45 AM
Starter problems
Thanks! I'll apply the BFH today and see if it helps. (first aid)
I'll probably replace the contacts anyway, do you have the partnumbers of the contacts?
And how hard is it to replace them?
Do I need to do anything special to remove the starter? (e.g. prevent oil leakage)
09-01-2005, 10:25 AM
Starter problems
There are 2 ways of taking the starter of banpei:
1: least stressfull method, more expensive: detach exhaust manifold to make room to get to the starter, then just loosen the 2 bolts and disconnect wiring.
2: Method I used (on the older type starter):
Get under the car, take off the small metal heatshield that's bolted to the starter engine. Try to disconnect wiring as far as possible, loosen bolts holding the starter in place (You can reach one from under and one from above the car). Now with the starter loose, you can manouver it out between the exhaust manifold and firewall.
I've used this method 3 times, it is a pain to do and it will leave some wounds on your hands before your done, but you will save on the cost of exhaust gaskets.
  Big wheel problems gh0st 16 8,402 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 2,686 08-31-2021 06:20 PM
Last Post: totta Crolla
  AE86 starter options max_ae86 12 30,535 07-28-2019 08:17 PM
Last Post: harkes
  Problems Mintex M1155 pads Dino86 9 9,069 07-04-2017 11:22 AM
  16v Bigport fuel problems Rascal21 1 4,800 07-04-2015 01:00 AM
Last Post: jondee86
User(s) browsing this thread: 20 Guest(s)
