Strut nut tool
12-01-2008, 01:18 AM
Strut nut tool
Hey guys im after the tool that takes off the nut on top of the strut casing. This allows the dampers to be taken out.
I want to know what that tool is called and where could i get it. Also if other ppl have different methods in taking the nut off i will be pleased to know thx Alex |
12-01-2008, 01:25 AM
Strut nut tool
I used a really large wrench .....
12-01-2008, 01:44 AM
Strut nut tool
cool do u know the size of the nut ?
12-01-2008, 06:32 AM
Strut nut tool
Clamp the nut in a bench vise, and then rotate the strut. A vise is
like a large adjusting spanner... one vise fits every size of nut Cheers... jondee86 |
12-01-2008, 02:01 PM
Strut nut tool
hehe i tried that before and it kinda deformed the nut quite bad
12-01-2008, 04:54 PM
Strut nut tool
if you order agx dampers youll get a new nut with them.
T3 is selling new nuts too |
12-01-2008, 06:01 PM
Strut nut tool
Eric Wrote:if you order agx dampers youll get a new nut with them.I bought SW20 AGX dampers for my AE86 and found out that the nuts that came with them used a different thread and didn't fit on top of the AE86 struts. Maybe the AE92 ones come with nuts that have the correct thread for AE86? |
12-01-2008, 09:15 PM
Strut nut tool
For the SW20 AGX inserts I used the OEM strut top nuts and had some
material removed from the inside in a lathe. Otherwise, you could try and get some nuts from your Koni dealer. Cheers... jondee86 |
TUV - Strut brace | pack | 3 | 5,329 |
09-08-2018 08:17 PM Last Post: d3nso |
Need urgent help strut mounts. | ditn | 5 | 7,590 |
01-21-2012 03:37 PM Last Post: ditn |
front strut lenght comparison problems | fax0815 | 6 | 7,572 |
01-25-2011 04:12 PM Last Post: fax0815 |
Rear Strut | heshan | 5 | 6,216 |
01-02-2011 02:56 PM Last Post: Sam-Q |
techno toy tuning rear strut tower braces....installation ?. | J_who_ez | 14 | 18,037 |
09-18-2010 04:33 PM Last Post: PatrickAE86 |
