T3 LSD rebuilt kit = Crappy Noise when I trying to drift...
07-02-2006, 01:40 PM
I have just rebuilt my stock LSD with T3 kit...I go for a little drift on dry road...After few , the diff start to make a crazy fucking noise !! I thought that I broke my diff , but after running a little , the noise disapear...I start to drift again , same noise for about 15 secondes et then disapear...
I think there is a problem with the LSD...I'm a jerk , I'd rather bought a NEW LSD from the beginning... What do you think ? Maybe someone have the same problem... Thank you very much !!! ( Sorry for my english ) |
07-02-2006, 02:12 PM
what kinda noise ?
like clak clak clak or something like a constante winning noise zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz ? |
07-02-2006, 02:58 PM
gon Wrote:what kinda noise ? It's more like "Clak Clak Clak"...When accelerating , it becomes noisier... |
07-02-2006, 05:06 PM
I think it just needs bedding in. Someone else could probably vouch for this better than me but you should do figure of eights for about half an hour then change the oil and it should be fine. Don't take that as gospel though, it's just generally whats done when replacing an LSD and I would figure it would also mean the same for a rebuild.
07-02-2006, 05:09 PM
I dont know what's wrong with your diff but T3 kit contains only stock toyota parts. Maybe you have a damaged clutch member or something.
07-02-2006, 10:15 PM
When I rebuild my diff with stock Toyota parts, I drive for about half an hour " 8 " and when I make a turn to left or right, I heared noise from diff ( clak clak clak ) or sometimes wheel spin and that make noise too.
After 200 km of normal driving, I changed LSD oil, and that is that. Now, after 4000 km, I hear "clak clak" sometimes, on good road in full turn. 1984 AE 86 Levin hatchback 1989 AE 92 GTi 2004 Kawasaki KLE 500 CROATIA - small country for great drift |
07-03-2006, 12:13 AM
had the same thing, after a rebuild, using the proper kind of LSD-oil fixed it for me.
He attacked everything in life with a mix of extrordinary genius and naive incompetence, and it was often difficult to tell which was which. |
07-03-2006, 11:12 AM
Thanks everybody ! I will try to change LSD oil :wink:
07-03-2006, 12:13 PM
break in your LSD first BEFORE drifting!!! we usually recommended our customers after the rebuild to drive their car normally for about 1000 miles and then change it to better LSD oil. this will apply to BRAND NEW LSD OR REBUILD LSD.
P.A.S.S Racing 148 S.8th Ave, Unit-F (626)961-6284 City of Industry [email protected] http://www.passracing.com |
07-03-2006, 04:09 PM
yes , do 8's like in the KAAZ site after a rebuild and then change oil, after something like 1000km it should only make that noises when the oil is hot and not in normal driving. And that is normal
READ THIS: http://www.kaazusa.com/techHelp/tech_Help.htm |
TRD Short Shifter Rattle Noise, It's Normal? | Mattolo | 19 | 19,205 |
04-27-2024 10:04 PM Last Post: banpei |
Clicking noise from glove box | chrisae86 | 4 | 1,867 |
09-08-2022 11:36 PM Last Post: chrisae86 |
Noise Insulation for AE86 | decryphe | 1 | 3,972 |
11-03-2016 11:51 AM Last Post: mad.matt |
Whining noise HELP PLEASE | izanagi | 10 | 11,994 |
03-26-2015 06:48 PM Last Post: Komba |
Whining noise only in 4th & 5th. | izanagi | 7 | 10,489 |
09-25-2014 07:09 PM Last Post: Uzelac |
