T50 rebuild kit
12-15-2011, 01:43 AM
T50 rebuild kit
Nice DIY!!!
Thats the bearing not longer avaliable from Toyota? 44 - Input shaft bearing I will check with my bearing dealer, maybe he can source them and give us a quote. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
12-16-2011, 05:37 PM
T50 rebuild kit
Little more help. I ve got all bearings #:
1) KOYO 04NUP0517 2) KOYO 04NUP0515N 3) NACHI 30PU554C/40 4) NSK 30TM02UR 5) NACHI 6305Z , 25BC06547 6) NACHI 30RT0653N , 30RT0653C/50 |
12-16-2011, 05:51 PM
T50 rebuild kit
PatrickAE86 Wrote:I was able to get almost any thing from toyota NL...how much do you paid for that ? |
12-16-2011, 09:45 PM
T50 rebuild kit
320 euro's
'87 levin coupé |
12-17-2011, 02:01 PM
T50 rebuild kit
That roller bearing for the input shaft looks really nice, obvious Toyota attention to detail & over engineered. If it was a factory only & no longer available or astronomical $$$, it can be replaced with a ball bearing.
Just expect a shorter life & maybe need some shimming to put it in the right spot. So what! |
12-17-2011, 02:50 PM
T50 rebuild kit
A guy on Club4AG ordered his kit here:
http://allstategear.com/ ezoo Wrote:450$ i think thats with shipping to europe tho.http://forums.club4ag.com/zerothread?id=99379 (Without the roller bearing.) We can find from other retailer by googling: BK244WS |
01-02-2012, 10:36 AM
T50 rebuild kit
fax0815 Wrote:I will check with my bearing dealer, maybe he can source them and give us a quote. Any news about that ? |
01-03-2012, 01:24 PM
T50 rebuild kit
Project D Wrote:fax0815 Wrote:I will check with my bearing dealer, maybe he can source them and give us a quote. He said, the number (30RT0653N) is not listed in any catalogue and I should bring an old bearing into the workshop, to take some measurements. I can do that, but someone needs to "borrow" me an old bearing, since I don´t have one... 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
04-01-2013, 12:37 PM
T50 rebuild kit
my speedometer stopped working so i pulled out the cable and connected a drill to it and the speedometer reacted so it must be the sensor, pulled out the sensor and saw that teeth were missing and there were 2 pieces of steel in the hole.
1 piece is the clip that holds the speed drive gear inplace, the other steel part is the steel cover of the rear bearing.Gearbox functions good but i wanted to check out if nothing else is damaged so i swapped it out with a gbox that was lying around here. this box whines, only wants to shift to 2nd gear when the engine is warm or if you synch with first gear first, and the speedo seems to be of, might be an sr5 speedo drive gear. other than that the hachi keeps rolling and i can open my 'own' box without having to stop driving Brings me to this topic, im gonna check what the state is of my gearbox and might be in need of bearings but i don't want to pay toyota prices.if the exact same bearing cannot be ordered maybe we can look for an alternative. Real men race downhill |
T50 gearbox | totta Crolla | 3 | 2,366 |
02-25-2022 02:35 PM Last Post: Project D |
Bluetop Engine Rebuild multiple question Goal 150-160hp | Hanzo | 16 | 9,090 |
Rear Differential rebuild | chenfon | 10 | 9,078 |
AE86 4A-GE 16v engine harness rebuild | FanIsHere | 7 | 9,920 |
T50 TRD gearset | DidiDex | 7 | 8,751 |
09-12-2019 07:36 PM Last Post: DidiDex |
