TRD Gearbox problem
05-30-2009, 12:48 AM
TRD Gearbox problem
My FRIEND broke the the gear from his TRD gearbox .
He's searching for a pinion (2).
He's got a well tuned engine :170hp . He use to have 140hp before but now with the power increase , He'd like to find something stronger .
Precision : it's for competition (rallye) and he needs short ratios .
Quaife is very expensive. A W58 is strong but stock ratio is'nt what he's looking for .
And of course he doesn't want something to expensive .
If you have solutions , I'll forward them to him , as he doesn't speak or read english .
It's not for myself
Phil
Filh
Save the RWD cars
05-30-2009, 12:55 AM
TRD Gearbox problem
Hi there
Did you know that you can buy just the individual gears from TRD to replace the damaged ones .I bought some for my spare gearbox a couple of years ago , what size pinion is he looking for ?
05-30-2009, 11:38 AM
TRD Gearbox problem
There is also the option of fitting Ford gearboxes... I believe Fensport once sold a conversion kit.
05-30-2009, 01:20 PM
TRD Gearbox problem
A friend of mine used a Quaife and it wasn't any where near strong enough.
A would use a Getrag M3 gearbox! Syncros gets worn but other than that it'll take a lot of abuse Thumbs up!
[Image: AEU86 AE86 - TRD Gearbox problem]
05-30-2009, 03:43 PM
TRD Gearbox problem
4ag to Ford bell from fensport, accepts the sierra 5 speed gear box,
multiple ford options
05-30-2009, 11:50 PM
TRD Gearbox problem
There was one guy on here that was supposed to update me with some type 9 (sierra) box pics and stuff... but that never came through, if you search for it, you can find the thread, it had a list of mods if I remember correctly.
Wow, I could have sworn I had an account here... I guess I'm the new guy Sad
05-31-2009, 12:12 AM
TRD Gearbox problem
Has your friend looked at W55 and W57 gearbox ratios?
http://www.geocities.com/MotorCity/Pit/9...boxes.html
Corolla Levin SR 1984 AE-85 (Project car)
Corolla Runx Z 2002 (Runabout)
06-02-2009, 11:34 PM
TRD Gearbox problem
To NZAE86 : the third gear pinion is dead . I think he bought the gearbox kit from a seller in France (MRS Passion I think ) .
I don't think it's still possible to get separate parts now .
I told him about W55/58 gearbox but he doesn't know the gear ratios value .
And I suppose it's not very easy to find such a gearbox in Belgium ?
I'll check and forward the link to him .
About Ford gearbox : I think it could be an expensive solution . And what about reliability. He spend a lot of money in the engine and i'm afraid he can't afford a big upgrade .
Anyway thanks for my friend
Phil
Filh
Save the RWD cars
06-03-2009, 11:30 AM
TRD Gearbox problem
W55/58 are supra gearboxes, i think you should be able to find some Smile
  weird gearbox part2(possible trd set a) ditn 6 6,919 01-31-2016 08:01 PM
Last Post: totta Crolla
  T50 gearbox - TRD 2nd and 3rd gear hachirokkos 3 6,540 11-27-2015 10:06 AM
Last Post: Project D
  4agZe problem solved - 99% IC problem Okami 41 35,608 07-12-2012 04:49 PM
Last Post: Okami
  Maybe problem with TRD shock absorber and springs Mattolo 22 20,314 10-15-2011 07:40 PM
Last Post: zenki
  AC problem? Idle problem? KD2229 3 4,728 08-19-2009 02:08 AM
Last Post: KD2229
